Tekno RC SCT410.3 Thread
#1714
Will do, thanks. On that note I am running Hot Boddies blue springs on the front which are basically the same rate as the Tekno pink fronts but a couple MM shorter. For some reason with Tekno front springs on the truck and my SL I can not get proper ride height and the truck is not good at all sitting at 28-30 MM up front. Think I'll shave the collars and try some Tekno greens up front next.
#1718
I don't have a 410.3, just the original 410 but I have had nose down issues. I run a Tekin Pro4HD 4300 with an 18t pinion.
#1719
hey matt I am running a tekin rx8 with hobbywing 4000kv with a 18 pinion
#1720
I'm sure this is true for some, my gearing is good. Its a issue that I believe I can fix with a setup change. I need to get the green springs back on the front and figure out how to get proper ride height with them on it hence my post earlier about shaving the collars down thin. I love the new truck and SL buggy, they are well built rigs and have steering like no other but honestly the springs that come in the kit and the ones from Tekno that you can buy do not work with the new towers/geometry, springs are too long. I have read all the "compress them before installing" and "they will settle in after a few runs". I try'd it all thinking I was missing something simple but it isn't me its the springs. We need shorter springs with the proper rates for the .3 and the SL IMO.
#1721
this may sound stupid but I have never run short course only 1/8 what rims fit the tekno 410.3?
#1723
Any designed to fit the LOSI SCTE are direct fit. Rims designed for the AE SC10 will fit as well, but the +3 option may put you past the legal width.
#1725
I just bought the new +3mm DE Speedline wheels. I'm hoping they do not rub. The Borregos are awesome wheels, just the rubbing issue is the only gripe. I have like 6 sets, they're a great wheel.
With that being said, if the +3 rub. I can only image the stock SCTE offset will rub even worse being that they are 3mm closer. I have noticed the AKA wheels have no ribbing at all on the inside. It seems like all the wheels flex, but keep an eye on the outer edge of the rear Arms... If they are worn flat. Then your wheels are rubbing.
My buddy raced the ROAR E nationals in PA, and he runs STOCK offset SCTE wheels and still couldn't pass the ROAR width test. The Rear toe IN was causing him to fail. He actually had to dremel the rear axle stub shaft ends to finally pass after 8 attempts. Crazy. Their rules are ridiculous from what I hear.
