Team Associated T5M Discussion >
Like Tree108Likes
Old 12-11-2015, 05:46 PM
  #2581
ben42's Avatar
This might be a really dumb question....but what all do I need for a 3 gear conversion for my t5m I just got? From my understanding I need the motor plate, gear cover, and gear box. Is that right?
ben42 is offline
Old 12-11-2015, 06:17 PM
  #2582
Jmuck69's Avatar
Trader Rating: 14 (100%+)
That's it!
Jmuck69 is offline
Old 12-14-2015, 01:33 PM
  #2583
Do the t5m and the sc5m use the same springs ?
sgtlt is offline
Old 12-14-2015, 03:00 PM
  #2584
I went to AE web site and looked and answered my own question. Yes they take the same shocks and springs.
sgtlt is offline
Old 12-14-2015, 03:03 PM
  #2585
stock kits come with the standard 12mm big bores in the t5m. and the truck springs in the sc5m. but yeas they can be swapped back and forth. make sure you use corresponding spring cup for the truck springs
robbie_gtc is offline
Old 12-14-2015, 10:30 PM
  #2586
Jpdanger's Avatar
Anyone here using the X Factory chassis? What set up are you using?
Jpdanger is offline
Old 12-15-2015, 07:22 AM
  #2587
Cridd's Avatar
Trader Rating: 16 (100%+)
I went down 2.5 to 5 in shock oils and 1 or two springs. A lot lighter.
Cridd is offline
Old 12-15-2015, 07:25 AM
  #2588
jakeb's Avatar
I'm using one here for MOD was previously running it with a 13.5 and a shorty with lighter shock oils and spring tuning. I just went back to the box stock setup and a square pack for my new race setup with a 9.5. I'll report back once I know how it goes.
jakeb is offline
Old 12-15-2015, 11:37 AM
  #2589
Braxamus's Avatar
I was told by Paul at X-Factory that their chassis is good for mod or stock you would just have to adjust the flex in it. However Jason Snyder said it would be to lite for mod and flex to much so, I guess it all depends on you individual driving style and your track.
Braxamus is offline
Old 12-16-2015, 07:02 PM
  #2590
Got mine on the track for the first time today. Wow this truck is amazing. I did switch to new truck springs, green on front and rear, the change was huge. Way smoother in jumping and landing with the truck springs. First day out and already running as good as my B5m and 22 3.0
sgtlt is offline
Old 12-17-2015, 06:20 PM
  #2591
Jpdanger's Avatar
I don't know why I didn't realize I had to lighten the suspension... I was running something similar to kit set up, but with the XFactory CF chassis which I now realize was too stiff for the lightweight. I thought I would start with just lightening the oil and went 30 front and 25 rear and it was perfect with the blue front white rear springs! The truck is much more forgiving and doesn't break loose in the turns anymore.
Jpdanger is offline
Old 12-19-2015, 06:31 AM
  #2592
hello all just curious what will change if i go to a lighter front spring? i have white on there now gona go to green.
DIRT DIGGER is offline
Old 12-19-2015, 09:03 AM
  #2593
Jpdanger's Avatar
You'll get more initial turn in due to more weight transferring forward on braking. Too much weight transfer forward and the rear end can break loose. Without getting overly technical, changing the springs on the front of the vehicle will affect off-power steering. Changing springs at the rear will affect on-power steering. You can also experience nose down jumping if the front end is compressing too much.
Here's a great cheat sheet to troubleshooting your set-up. I'd suggest printing the PDF at the bottom of the page and keeping it in your toolbox.
Jpdanger is offline
Old 12-19-2015, 11:33 PM
  #2594
duckhead's Avatar
Hey guys, just finished my T5M build, and I am looking for some tires recommendations. I am a buggy guy so this whole truggy thing is new to me.
The track that I am looking to run on is indoor clay, smooth, relatively high bite and sometimes wet.
Thanks!
duckhead is offline
Old 12-20-2015, 06:16 AM
  #2595
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
Thanks!
Stadium truck guy, truggies are 4wd...
I would say Ions, Dirtwebs, Pressure Points, or Chain Links. Pretty much any small tread height tire. In either clay or super soft/Ultra soft compound.
thecman26 is offline
