Serpent Spyder SRX-2 Mid Motor Buggy Thread
#1381
SCORE SCORE SCORE!! since purchasing this car i jsut couldnt figure out why the shock would bind near the top. I have gone back and forth with other via PM and email trying to figure it out. So today i was making and installing pistons and just could not figure out what was going on i even made the pistons undersize and it still does it. It finally dawned on me that it is the cartridge cap hole it seems to be molded slightly off center and too tight so i loosened up the cap just to see if that would help and it did. I took a 9/64 drill (3.5mm) drilled out the cap (previous size is .125 which is the same size as the shaft). this freed it up so much in the front that with no other changes my ride height went up 3mm!!
#1382
#1383
#1384
where can i find Casey's B.'s set up from OCRC
#1388
#1389
Here is my results and set up from this past weekend. This track is very unique because its outdoors but its also covered. The layout is tight with a lot of sharp 180's so maintaining corner speed is key. Traction is medium bite with a couple sections that were a little dusty from the track breaking apart but relatively smooth. The car performed great all day. I was able to push it but still feel in control of it because its so predictable. Just a blast to drive.
Set up
http://dialedsetups.com/default/sheets/view/id/1426
Set up
#1391
Anybody try the gear diff in mod yet? If so, what is a good weight oil to start with?
#1393
We run mainly on high bite clay and usually start the day on slicks since the track is so tacky. Idler gears stripped once since he started racing the car when it was first released. None of the other gears were damaged, just had to clean the teeth out. I wouldn't install aluminum unless you're running carpet/astro/sugar. Just keep a few of them on hand, or in a pinch the Losi 22 idler is direct fit.
#1394
A bad bearing chewed up my idler gear, hasnt happen since i replaced the carrier bearings.
#1395
