TLR 22-4 THREAD
#7546
Why hasn't RPM jumped on arms for this car? I'm a fairly new racer, stock last winter and 4w mod for the second half of the season and it isn't the least bit forgiving if you land crossed up. I have done things to my B5r (stock) that at the same speed in the 22-4 I think would have wasted the whole chassis and the B5 just takes it.
#7547
#7549
What tricks have you guys used for a little more steering? Mine is good when the grip is up, but I drove a xray xb4 and it had more which I liked.
I'm sure new tires would solve most of my problem but not sure if there's something else i'm overlooking.
Otherwise happy with this car still.
#7550
Just don't see a durability issue compared to the AE car. A lot of the AE guys around here tell us the opposite! Tyler drove his 22-4 all winter like an ebuggy and finally broke both front arms at different races. Car totally parts other than aluminum servo on the steering servo. This was by far the most durable car around all last winter. His car is flat wore out now from all the racing. Same belts and pulleys all season too.
#7551
TLRacing
I think you'll find that 4wd car to 4wd car, the 22-4 stacks up pretty well in the durability category.
#7552
I have the Exotek front brace and that helps a lot.
Ive only broken an arm when hitting a pipe at full speed and when someone crashed into my arm coming off a jump.
Belive you me I've tumbled here lol.
If it was beefier around the hinge pins they would not break at all.
#7553
Rc Shox ctr diff and roller front pulley
Guys,
Has anyone tried theRC Shox Ctr Diff and roller front pulley on there 22-4? if so what sort of surface? and what was your opinion?
Have got them installed in my car ready for its first run with them in and a refreshed car. First run will be on astrofurf, i am hoping these parts will help the car lots.
Any input is appreciated.
Cheers
Cheers
#7554
Guys,
Cheers
Cheers
#7555
Guys,
Cheers
Cheers
#7557
Hi there,
I have a small question about the hinge pins of the 22-4:
- could you please tell me the length and the diameter of the threaded hinge pin (part no.: TLR234037)
I guess the threads are 3mm (M3)?
Thanks a lot for your help,
Regards,
G-rem
Regards,
G-rem
#7559
Frank,
Could you post your current setup? i noticed you said you have been running 1.7 x2 pistons on the rear. If you change from stock to these, did you change oil or spring rate to keep the same feel? Also with this setup do you still run the 1.7 x2 in the front as well?
#7560
when will the 12* caster blocks be available? saw them on a few team cars last winter and thought we would have them by now. thanks
