Like Tree28Likes
TLR 22-4 THREAD
Old 03-23-2014, 08:36 PM
  #4306
Trader Rating: 33 (100%+)
Originally Posted by uclabruins89
That is the bad sound of your diffs slipping. Tighten them way up. Mine are within 1 turn back of locked.
How do you know when you are at locked? I get one full rotation at the rear and about a half rotation on the fronts.
dnuggett is offline
Old 03-23-2014, 08:38 PM
  #4307
Originally Posted by UN4RACING
Try another motor. It sounds like you may have a bad bearing? Be sure the pinion is not to tight or loose to the spur as well?
I'm going to assume for the moment it's not the motor. It is a brand new Reds. I'm going to try to rule all else out before going to another motor.
dnuggett is offline
Old 03-23-2014, 08:40 PM
  #4308
Originally Posted by Roger H
Check diffs, and also use the method root says for checking the slipper, if there is anything slipping you will find it quick. Also whats your gearing?
Where is Root's method? I followed Hodge's video. Gearing is 17/84.
dnuggett is offline
Old 03-23-2014, 08:41 PM
  #4309
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Got it be sure to let us know I want to know who got it??? I'm ruling out the diff at 3/4 throttle. they would be at low end most likely..
UN4RACING is offline
Old 03-23-2014, 08:44 PM
  #4310
Fair enough. I'm not saying your not right.. only that desoldering everything and buying another motor is the last resort.
dnuggett is offline
Old 03-23-2014, 08:46 PM
  #4311
UN4RACING's Avatar
I'm having an issue with my 22-4. When I am on the throttle 3/4 or better I hear a higher pitched sound, a sound I thought sounds like the same sound Hodges displayed when he was setting the slipper. I can't get enough speed to clear a simple double, and down a straight it doesn't gain the speed I know the car is capable of. I thought it might be the rear belt, so I set it at a tight setting. That didn't fix it so I thought it would be the slipper not being set tight enough. I tightened the slipper so the screw went slightly past the nut. Still have the same problem. Any ideas?
The motor is a 6.5 and the ESC is an Orion R10 pro... it should have plenty of power to clear a double and haul down a straight.
Okay I re read it from another view. 3/4 throttle from low end? Not when your at 3/4 throttle like on the straight? I'm losing this one...LOL
Old 03-23-2014, 08:47 PM
  #4312
UN4RACING's Avatar
Borrow one dang it....!
Old 03-23-2014, 08:52 PM
  #4313
Sc Sandman's Avatar
You may have a pinion that has been machined slightly out this can also cause the noise you are hearing.
Sc Sandman is offline
Old 03-23-2014, 08:55 PM
  #4314
You won't be able to rotate them opposite directions anymore when locked
uclabruins89 is offline
Old 03-23-2014, 08:56 PM
  #4315
If I'm not on the throttle but moving, like out of a 180 turn and head into a jump and I need to get on the throttle enough to clear the jump, it will happen. If I come out of a turn to a straight and already have some good speed through the turn, but hit the throttle to head down the straight it'll happen. I estimate it to happen when I transition from no or little throttle to about 1/2 or 3/4 throttle.
Maybe it's the slipper, but I have it tighter than most people already. The screw is slightly past the nut.
dnuggett is offline
Old 03-23-2014, 08:58 PM
  #4316
It's not about having one actually.. I have 2 other 6.5s, a 7.5 or a 9.5 I can try. It's the soldering that I don't want to do again. Especially when the chance of it being the motor are the slimmest.
dnuggett is offline
  #4317
Roger H's Avatar
Trader Rating: 24 (100%+)
Roots method can be found on youtube. I did a quick search of 22-4 diff setting.
17 seems a little low to me, i run a 21 on my 6.5 and a 19 on my 5.0
Also to cover all options i would remove the slipper assembly and throughly check everything and reassemble per the manual just to be safe. Its possible a part got flipped in the wrong direction. While its apart i recommend doing the tech tip on sanding the slipper shaft by Jose. Much smoother clicker when completed.
Roger H is offline
Old 03-23-2014, 09:06 PM
  #4318
This one? https://www.youtube.com/watch?v=voqmS6vNw5A
Isn't that Hodges?
dnuggett is offline
Old 03-23-2014, 09:10 PM
  #4319
I'll remove the slipper and recheck it. 17/84 is too low? Phends setup sheet showed a 16/84. I'm not saying I'm Phend by any stretch but his is lower then mine and I'm willing to bet he doesn't have the problem I have.
dnuggett is offline
Old 03-23-2014, 09:17 PM
  #4320
Roger H's Avatar
My 6.5 comes off the track cooler with the 21. It was roughly a 20-25 degree differance with the 18.
Roger H is offline
