Like Tree28Likes
TLR 22-4 THREAD
Old 02-11-2014, 08:34 AM
  #2851
Beau S's Avatar
Originally Posted by nicmo
As you can see the shock shafts work great, i borrowed my 22-4 to a friend and he drove it into a wall lol. Broke the Aluminium Front Pivot Brace and the lower pivot plastic piece that holds the hingepin.
shock shaft and front arm, intact.
My Hero!! When you break, you do it all out! lol
I don't think anyone will Q: using the shock shafts as hinge-pins now! haha
wow!
Beau S is offline
Old 02-11-2014, 08:42 AM
  #2852
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by jzwolen
Anyone know when the new TLR cab forward body will be available?
It is going to be a while yet, and we have no accurate date at this time.
Frank Root is offline
Old 02-11-2014, 08:47 AM
  #2853
gijoe64's Avatar
Trader Rating: 30 (100%+)
Originally Posted by BmainStar
You know that You are allowed to downside the jumps ,,Right???
So true Riverdale!!!!!
Chris went Dukes of Hazard on that triple!!
gijoe64 is offline
Old 02-11-2014, 08:54 AM
  #2854
Mystic's Avatar
^^^^ I would no longer lend my car to that friend.
+2
Mystic is offline
Old 02-11-2014, 08:55 AM
  #2855
Carranza76's Avatar
Hey no one asked you Riverdale!!!!
lol
those still shouldn't have broke.
And ray why you laughing you broke one on a rhythm section!!!
at least i had the balls to take a jump! lol
you asshats!
Carranza76 is offline
Old 02-11-2014, 08:56 AM
  #2856
Mystic's Avatar
I am a relatively new driver, what exactly is " downside a jump" ? Does that mean landing on the backside slope of the receiver ? ( yes this a serious question )
Mystic is offline
Old 02-11-2014, 08:57 AM
  #2857
Carranza76's Avatar
Yes that's what he means and its something every rc drive should strive for, makes for faster laps and keeps the car settled on landing.
Old 02-11-2014, 08:59 AM
  #2858
Mystic's Avatar
Ok thank you
Mystic is offline
Old 02-11-2014, 09:04 AM
  #2859
gijoe64's Avatar
Yeah you need to get that down! Lol
gijoe64 is offline
Old 02-11-2014, 09:11 AM
  #2860
That's a $30 crash, I'd say. When my son wrecks his B4.1, I can usually tally up the cost in damage before the car comes to a stop.
frankenstang is offline
Old 02-11-2014, 09:18 AM
  #2861
RC Bombshells's Avatar
Trader Rating: 143 (100%+)
Default CHA-CHING!
That's funny! Sounds like a Barrett-Jackson Auction while the B4.1 tumbles down the straight away........
NITROTENSCT likes this.
RC Bombshells is offline
Old 02-11-2014, 09:21 AM
  #2862
subaru_tech's Avatar
Trader Rating: 106 (100%+)
clearly that wall should have gave way before doing that damage to the car
subaru_tech is offline
Old 02-11-2014, 09:22 AM
  #2863
Default Remove your set screws
Originally Posted by WIGMAN
The only problem with your solution is the set screw does not tighten up against the pin, it just sits beside it in the notch, there is no way to tighten the screw against the pin so there is no pressure on the pin from the set screw.
FYI,
TLR posted a solution to the hinge pin issue on Facebook the other day. The set screw is not needed. The bumper keeps the pins in place just fine. Since removing the set screws, no more breakage issues.
Old 02-11-2014, 09:24 AM
  #2864
Downside
That means land you car on the down slope of the jump
Whatch a supercross race
Then think about that guy on the dirt bike of the outcome if he over jumps a triple and lands in the flats
Not good
When the guy next to him lads perfectly on the down side he gets the power to the ground and the inside line in the next corner
When you over jump I to the flats u pan out the car and blow the corner
B rad919 is offline
Old 02-11-2014, 09:32 AM
  #2865
Default 22-4 first drive
Finally got my kit on the track last weekend
I have too say I have driven and owned every kit and where the 22-4 excels IMO is you can over drive this car very aggressive and it does not get edgey or upset
It jumps and takes the bumps just like you would expect a Losi to do
This car is a slam dunk and highly recommended
Thank you TLR
B rad919 is offline
