Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 04-17-2015, 03:10 AM
  #8881
Suspended
Originally Posted by egobrkr
So wanted to share an issue that has come up a few times running my buggy. The front sway bar comes out of the plastic end holders. I'm not sure if anyone else is having this issue but it is annoying me. I will buy some new ends and see if that works or see if I can find aluminum ones that will work. I try not to tighten down the set screw because it's plastic.
Seems that most people that do a lot of durability testing have this issue. I'm still building my D413 and I'm going to grind a small flat spot on the sway bar so the set screw locks into the bar. Should help keep everything in place. That said, I don't really crash so I'm probably not a good person to test if my fix will work.
How would you pop an aluminum ball cup onto a metal ball stud?
Mantis Toboggan is offline
Old 04-17-2015, 05:36 AM
  #8882
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Just you and the other guy Make sure that the sway bar is 100% free. It should fall freely under its own weight with the ends not attached. You're car will handle a lot better as well.
If the set screw has stripped you can run a 4-40 screw (little bigger dia) right in the same hole. It works just fine.
Yeti AS3 is offline
Old 04-17-2015, 06:08 AM
  #8883
I hit the swaybars with the Dremel and put a small flat on them for the screw to bite on.
Also after threading the screws in and stripping one hole I removed them, wicked a drop of thin CA in and let it cure up. Then reinstall the screws and they are a nice tight fit.
Do this with cars with droop screws in the arms too and they won't adjust them selves.
GimpyGolden is offline
Old 04-17-2015, 06:44 AM
  #8884
I replaced the set screws in the sway bar ends with 2mm longer ones... they don't strip out so easy. Easy way to do it... swap the set screws from the shock towers and the sway bar ends.
Sofa King is offline
Old 04-17-2015, 07:11 AM
  #8885
Trader Rating: 49 (98%+)
What are you guys running for a battery setup? Shorty or saddle packs?
wheres_yogi is offline
Old 04-17-2015, 07:57 AM
  #8886
Jakesterama's Avatar
Trader Rating: 68 (100%+)
I have seen very few people run saddles. This car is really designed for the shorty setup and the saddles is just an option to keep it ROAR legal IMO.
Jakesterama is offline
Old 04-17-2015, 08:52 AM
  #8887
mvrk28's Avatar
For those of you running 5.5s in this car, what are you gearing it at?
I was thinking of going 21/72 with my new Fantom 5.5, running my RSX at throttle profile 1 with 0 boost, 0 turbo and running max 5 degrees can timing.
mvrk28 is offline
Old 04-17-2015, 09:07 AM
  #8888
nitro2be's Avatar
+1 leave loose never had a problem either
nitro2be is offline
Old 04-17-2015, 09:09 AM
  #8889
nitro2be's Avatar
21 works great, little warm, timing if your gonna use a motor fan
nitro2be is offline
Old 04-17-2015, 09:17 AM
  #8890
Trader Rating: 17 (100%+)
Default Loose arms
After 2 months all of the arms are loose on the inner shafts, as if the hole diameter are wearing larger. Whats yours like? Time for new arms?
bladeys is offline
Old 04-17-2015, 09:23 AM
  #8891
mvrk28's Avatar
I have a fan on order, but it won't be here initially. I have a 24 on hand but I need a higher FDR than 24 will offer.
mvrk28 is offline
Old 04-17-2015, 09:43 AM
  #8892
MasiisaM's Avatar
Maybe start there and see how it works for you...
Whats the grip levels at your track?
If it was me I would also try no can timing...with a 5.5 it will help in being smoother. By going to the mildest curve and then adding some back in can timing kinda works against each other... with really just adding heat.
For sure play with Throttle profiles...but don't forget to also play around with throttle min and current limiter.
The trick is to give that thing the most usable power down low...cause that 5.5 will be a monster on top.
MasiisaM is offline
Old 04-17-2015, 10:32 AM
  #8893
nitro2be's Avatar
me too, I just play around with little lock nut and screws until play is gone.it will Last one time to track. I'm thinking new arms too but these are like old faithful.
nitro2be is offline
Old 04-17-2015, 11:11 AM
  #8894
mvrk28's Avatar
I'd say my track is medium traction. I'm going to run it at 0 timing and throttle profile 1, I'm running my 10.5 at throttle profile 2. I run 0 drag brake with a +5 on push control. Thanks a lot for your help, don't be surprised if I PM you to pick your brain!
mvrk28 is offline
Old 04-17-2015, 11:22 AM
  #8895
Yeti AS3's Avatar
Questions??
Speed passion 5.5 with r10 esc. 5 turbo (just never changed it) 22 pinion, no motor fan, 60 deg air temp. Comes off at 155ish after a full pack.
Yeti AS3 is offline
