Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 05-10-2015, 10:48 AM
  #1456
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Here is a link to all of the above information on one page, click here.
Thank you Teufel Racing and Arn0!
Kraig is offline
Old 05-10-2015, 01:16 PM
  #1457
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
You're welcome,
Hope it helps guys out.
If anyone is interested you can just use a normal ball for the shock rod end, it'll float a little and you could use an o ring to keep it tight if people don't want to cut up the shock stand offs for the RB6 like it did.
Teufel Racing is offline
Old 05-11-2015, 11:51 PM
  #1458
Has anyone tried the new zx6 chassis??
How much does it move the motor ?
Any pics of it mounted up on a car? Can't see anything on Google
Headling is offline
Old 05-12-2015, 07:35 AM
  #1459
The new chassis is not here yet... Maybe some team drivers have it but I have not seen any pictures of it mounted up. If I see anything I'll post it up here.
Arcain41 is offline
Old 05-12-2015, 05:06 PM
  #1460
Thanks for the info Jeremy, I thought it was out in the market place
Look forward to seeing some pics of the new chassis mounted up on the car
Headling is offline
Old 05-15-2015, 09:20 AM
  #1461
Stevomatik's Avatar
Interested in a bearing kit for the zx6... Not much offered in a kit so I was wondering if it's the same as the zx5 bearing kit?
Stevomatik is offline
Old 05-16-2015, 01:19 AM
  #1462
Heres a photo of naoto's car at the Europe off road race on currently, it has the new chassis you can see the 2 sets of screw holes around the motor mount spur gear area. Apparently it's 8mm forward but you can also use the current position on the new chassis.
http://eos.redrc.net/wp-content/uplo...5/mat4_CF9.jpg
http://eos.redrc.net/2015/05/chassis...o-matsukura-8/
Tom87 is offline
Old 05-16-2015, 04:03 AM
  #1463
Yes, its the same as ZX5
hloland is offline
Old 05-16-2015, 01:02 PM
  #1464
Stevomatik's Avatar
Cool thanks
Old 05-20-2015, 12:24 PM
  #1465
Texas Racer's Avatar
Default zx6 optional chassis
I saw the chassis at the Kyosho web site for $106.99. What is going to be the difference between the old chassis and the new one (performance wise)?
Texas Racer is offline
Old 05-20-2015, 01:11 PM
  #1466
It'll likely have a different flex, but I'm guessing just by looking at the pic and comparing it to the current one
The biggest thing it'll do is allow for the center slipper to be moved 8mm and change the weight bias from to rear
Most will likely want the new chassis once the center gear diff becomes available, as that's what I'm thinking the biggest change is for.
Don't forget you may also. Red to pick up the new side guards and center shafts, if you want to use the full,potential of the new chassis.
Old 05-20-2015, 03:24 PM
  #1467
alex4r's Avatar
Is this new chassis something that will likely be included in kits as a running update similar to the RB6's revised chassis? Or is it more of an optional part?
alex4r is offline
Old 05-20-2015, 08:14 PM
  #1468
If I had to guess,
I'd say probably more of a optional part, for now at least. Simular to the LW chassis for the RB6. Seeing as the gear diffs are currently an optional part as well, it might stay that way for a bit, but hard to say what they'll do.
Old 05-24-2015, 04:05 PM
  #1469
symmetricon's Avatar
Trader Rating: 27 (100%+)
Hey guys, I'm trying to help a buddy out with his ZX6, it's a mess, I drove it and it oversteered everywhere. Is Is there any must try medium/high bite setups to try on this car like the Zahl Rogers setup for the RB6?
symmetricon is offline
Old 05-24-2015, 04:56 PM
  #1470
Try:
http://www.petitrc.com/setup/kyosho/...0816/setup.pdf
Or:
http://www.petitrc.com/setup/kyosho/...2125/setup.pdf
Or:
http://www.petitrc.com/setup/kyosho/...2125/start.jpg
Those should be of help.
One of my friends really likes Kevin's setup. I'm pretty close to that with a couple little changes and gear diffs. Seems to work pretty well for me
