Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 06-16-2015, 02:51 AM
  #1486
vikingen's Avatar
Trader Rating: 29 (100%+)
Originally Posted by didrace
anyone?
I've always used AE diff lube.
if the ring is damaged, obviously replace it. you must have really tightened it down hard
tighten it down but not to the point where you have to strain AT ALL. then back it off say 1/8th of a turn. put the car down and accelerate hard. the diff should not bark. if it does, its too loose so tighten a tad.
I run a tiny bit of slipper, which puts less strain on your diffs
vikingen is offline
Old 06-16-2015, 06:15 AM
  #1487
kman16jr's Avatar
Trader Rating: 56 (100%+)
Hey guys I just picked up a one run zx6 and seen that car doesn't have a hex in the ball studs,I noticed Lunsford is the same 4.8mm but I know they have the hex in them for easy adjustment,will these work with the stock ball cups or do I need the punisher turnbuckles as well?and also I am looking for a carbon fiber shock tower and can't find one anywhere,thanks!
kman16jr is offline
Old 06-16-2015, 07:07 AM
  #1488
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
The Lunsfords will work. Just use your tire hole punch to make holes in the ball cup so you can access the hex.
Kraig is offline
Old 06-16-2015, 07:12 AM
  #1489
kman16jr's Avatar
Thanks for the quick reply I will get some on order,already punched the ballcups until I realized the studs had no holes.lol.
kman16jr is offline
Old 06-16-2015, 09:00 AM
  #1490
Bezerk RC on Facebook. Great Carbon Fiber!
potatobed409 is offline
Old 06-16-2015, 11:20 AM
  #1491
kman16jr's Avatar
Default Ae pistons
I'm in a pinch to run the car this weekend and want to be able to play with pistons if I need to,will ae pistons fit?I have some at my buddies house.
kman16jr is offline
Old 06-16-2015, 01:50 PM
  #1492
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
Yes they will fit,
But you'll likely need to shim them on the shock shaft. I use the little 3mm shims for the arms. I think they come in .10 and .20 if I remember right. Otherwise you'll feel the shaft move just a tick before the piston starts to move.
Teufel Racing is offline
Old 06-18-2015, 07:15 PM
  #1493
Does anyone know where to find the floating servo mount Tebo is using?
gearit is offline
Old 06-18-2015, 09:11 PM
  #1494
Try Kyosho TFW 119...it should be the same like the one we use in the TF6 touring car but this one is not gunmetal but red
nitroargi is offline
Old 06-19-2015, 05:47 AM
  #1495
didrace's Avatar
THANK YOU VERY MUCH!!
Much APPRECIATED your reply.
didrace is offline
Old 06-21-2015, 10:56 PM
  #1496
kman16jr's Avatar
I'm thinkin I have to give up trying to find this avid shock tool in stock,anywhere in that matter.lol.
kman16jr is offline
Old 06-23-2015, 05:08 PM
  #1497
vikingen's Avatar
anyone with some feedback regarding running the Bezerk top deck for the ZX6 ?
vikingen is offline
Old 06-25-2015, 03:00 AM
  #1498
Default Bezerk top deck
I have them on my ZX6 and i like them, i can not comment on how they make a difference to feel of car as i only raced my ZX6 for 3rd time a couple nights ago.
But i did get 1st and 2nd, giving me 2nd overall plus i had fastest lap time only 0.5 off lap record
I would suggest getting a spare front top deck, i think there made thin to provide movement/flex in the chassis.
I didnt even notice that my front section was damaged, i ordered a spare + a rear shock tower so i have complete set now. (i did have a big accident ripped a poor guy's shock tower off ripping open diff casing.... i think that might have been it)
I have to say i really like the look of it, it is supposed to reduce weight and i feel it still offers some flex. Send message on facebook to buy
Recommended
I have mine down to 1612 grams with light weight battery and bezerk bits and lunsford balls and arms
Dmitri Tech is offline
Old 06-25-2015, 07:45 AM
  #1499
symmetricon's Avatar
Trader Rating: 27 (100%+)
I'm still struggling to get my friends zx6 to run right. I put kings setup (minus gear diffs) on it and the car was still a mess. At high speed its twitchy an mid corner the car wants to step out.... gonna try to widen the front track width and lengthen the wheelbase... any other tips?
Oh, and I'm putting the gear riffs in it too..
symmetricon is offline
Old 06-25-2015, 12:19 PM
  #1500
Which King setup did you go with? Cody or Kevin?
I've been using one of Kevin's setups and it's pretty good for me. A couple slight differences that I went with, gear diffs and the 7 front hub carrier vs the 10 that most seem to run. The 10 degree ones alway seem a bit too twitchy for me.
I've let a few guys drive mine and they say it's easy to drive, which is one thing that I like to have. Might not be the fastest on the track, but if it's a predictable and easy car to drive, then it's a couple less things I have to worry about. Just put most of that setup on one of the guys car that had drove mine and he was happy with it. Before he had been struggling with it being inconsistent felling to him. One day it'd be good and on another it wouldn't be.
Side note on the gear diffs,
Make sure you do the bearing mod, it really helps. After having ran mine for a good while, it seems that they like to be driven just slightly more on power than the ball diffs did. Not sure of its a good thing or bad thing, just one difference I felt between the two.
