Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
#2236
I just picked up a secondhand zx 6.6, intending to use for stock 17.5 (australia). But it seems like the CD only has spur size of 78t?? Basically makes it impossible to get correct gearing if so. Can someone confirm if smaller spur gears are available for the centre diff?
#2238
You can go lower. I have a 76t in mine.
#2239
Spur Gear(48P-76T/ZX6.6)
#2242
The Kyosho center gear diff will seal and not leak if built property. The leaks that I’ve experienced were from me over filling it and it pressurizing or with me not sealing it properly after rebuilding it. I’ll reuse the large o-ring and gasket only if they’re in good condition but if not I’ll rebuilt mine using new gaskets, TF261-04 (Diff. Gasket Set). I also build my center gear diffs using the same sealant that the MP9 guys use XGS151 (Diff. Gear Seal Grease). It’s red in color and I use it on the large o-ring and the gasket.
If your case is warped then you’ll need to rebuild your center gear diff with a new case LA375-01 (Center Diff. Gear Case). Don’t over fill it and don’t over torque the screws for either the case halves or the spur gear and you should be good.
-Steve C.
-Steve C.
#2243
ZX6
Does anyone know if Tebos’s top plate for the ZX6.6 will work on the ZX6?
#2245
Just picked up a 4wd zx6.6 and started to build. Been reading some past posts on the car. Seems like some have had issues with blowing out the spur. Not sure what would cause that. What are some of the other issues this car may or may not have? Just trying to weed them out during the build before I put it on a track and learn the hard way. BTW, my track is medium size indoor with lots of grip.
#2246
#2247
Thank you for the response. I would imagine like any kit....if its built correctly things should run correctly. I will definitely have plenty supply of a-arms and the such.
#2248
Any rumours on a new car in the near future?Thinking about getting one...don't want to buy one and hearing there's a new car in the pipe.
