Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 07-19-2017, 03:12 AM
  #2206
I have given the Yokomo YZ4 front arm a go, while they are stronger in the middle of the arm, there is less material around the arm where the inner hinge pins go through and mind broke there.
200sxr is offline
Old 07-19-2017, 09:11 AM
  #2207
Gayosaka's Avatar
Originally Posted by jeromerc
I talked with Yuichi Kanai and asked him about making composite front arms like the TKI4 and he said he would look into it. He didn't seem to think it would take much modification so hopefully they will be in the works soon
Isn't Mr Kanai only designing the 1/8th stuff? Anyway I could do with stronger ZX6 parts! Breaking front arms and caster blocks is getting old.
Gayosaka is offline
Old 07-19-2017, 05:40 PM
  #2208
jeromerc's Avatar
Yuichi Kanai works for Automodel who supplies all of the Kyosho parts. Yes he is mainly designing the 1/8 scale, but I know he has pull and just because their bread and butter might be 1/8, it never hurts to improve the 1/10 stuff as well. I also talked with one of the younger drivers that just started running 1/8 (and won the masters) about beefing up the arms too. He said it was a great idea and he would also push for their development. He also showed me how to build their ball diffs. Cool guys all the way around at the Kyosho masters for sure.
jeromerc is offline
Old 07-20-2017, 11:53 AM
  #2209
tkge's Avatar
Trader Rating: 123 (100%+)
Originally Posted by jsrracing
I race at the 405 in OKC and its high grip clay ,prime is the only tire lol.
I just finished bulding my 6.6 I'm using the base clay setup mostly . The most notable changes I run orange ae front springs with 45 losi and 1.6 front gear diff is 30,000 with 500,000 center and 10,000 rear ,rear shocks are 40 losi with 1.6 , I will try to get a video up ,wed night I should the correct sway bars instead of the stock .
tebo carbon ,fantom 10.5 20/78 gear and protek 3600 shorty o arms in rear and hubs are centered
here is a short video , keep in mind this is the 2nd qual and the first race out ,its the blue red and black only thing that's not a losi ugg .Its also the first time I have raced a 4weeler in 10th scale
https://www.facebook.com/shane.ellio...3492281050555/
my thoughts on the buggy ,Its fast its fragile by arms and c blocks and pins and towers . I don't mean just one I broke in one night 2 arms 2cblocks and one carbon rear tower . if you note the wall when u make a left at he end of the straight I hate slowing down lol and I just rubbed it .
Thanks for the info. I will try to make it up to that track one day, its only about 4 hours from my house. I have not broken anything on my car yet. I have all the JTP carbon options on my car as well, the towers are pretty tough.
Deerek761 likes this.
tkge is offline
Old 07-22-2017, 11:06 AM
  #2210
Default Rb6.6 arms
When I'm changing to these arms, where do I mount the sway bar mount? Maybe this has already been discussed but I can't find it.
450rdawg is offline
Old 07-22-2017, 09:27 PM
  #2211
tobamiester's Avatar
Trader Rating: 360 (100%+)
Rear arms I presume. Check the ZX6.6 manual http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
tobamiester is offline
Old 07-27-2017, 05:53 AM
  #2212
Ahhhhh! When all else fails, read instructions. My bad, didn't even think about that but thanks.
tobamiester likes this.
450rdawg is offline
Old 07-31-2017, 09:59 AM
  #2213
LoudOne's Avatar
Trader Rating: 36 (100%+)
Hey folks.. I still have not built my ZX6.6 yet and was wondering what motor I should get for it?
I'm looking for an 8.5 turn and considering the Tekin Redline Gen 3 and the REDS VX 540. Thoughts?
LoudOne is offline
Old 08-05-2017, 10:13 AM
  #2214
Where can I find zx6.6 setups for 13.5 clay indoor?
CPTMorgan is offline
Old 08-05-2017, 04:14 PM
  #2215
jag5508's Avatar
Trader Rating: 15 (100%+)
I haven't ran my zx6 in a while looking for a turf and carpet setup for it . Either 13.5 or Mod just somewhere to start .
jag5508 is offline
Old 08-06-2017, 04:20 AM
  #2216
jeromerc's Avatar
we have a short carpet track with only one straight, I am running a 6.5 turn and it is a blast, in my 2wd buggies I run the 7.5 and there is a night and day difference, and with it being 4wd using the brakes is not an issue. I personally would put a 6.5 in it and not mess with an 8.5, in a 2wd buggy I might go 8.5 as the 7.5 on the straights are a bit fast at the end. Just my 2 cents...
jeromerc is offline
Old 08-11-2017, 06:10 AM
  #2217
Trader Rating: 155 (99%+)
Having a very strange problem. Just put in a new servo in to a ZX6. Went from a Spektrum 6240 to an MKS. Now the spektrum is much like the Savox where the top of the case is sort of cut down where the MKS is pretty much a box. My problem is now I have very little throw before the ball cup is hitting the top of the servo case. Anyone else have this issue and if so how did you remedy it. Short video of the problem below in the comments
Thanks in advance
skoalisbad4me is offline
Old 08-27-2017, 12:36 AM
  #2218
Suspended
Hi guys, thinking about getting one of these Zx6.6's, just a quick question, the servo can be mounted on either side by the looks of it, do you need any option parts?
Also how good are these cars? xb4 comparable?
Cmgreen is offline
Old 09-02-2017, 03:54 AM
  #2219
Suspended
any one?
Cmgreen is offline
Old 09-02-2017, 05:07 AM
  #2220
No parts needed.
You need to trim the lugs of the servo mounting plate and turn it upside down, I used slim plain nuts and locktite to secure it as I didn't like how few threads were left.
RogerM is offline
