Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 07-23-2018, 05:23 PM
  #2356
oPAULo's Avatar
Been running 4wd for a few months now. I've seen the left handed thread axles for the front end and finally figured out why it could be an issue. I've been running DE wheels and my son has been running KYO wheels. The DE wheels are not as deep in the hex as the KYO wheels and I spun a wheel off and stripped out the hex. Once I spun a wheel off it will absolutely not stay on. Falls off everytime. Tried locking nuts and even tried 2 nuts. Anyone have a similar experience? Know of a 4wd front with deeper hex?
oPAULo is offline
Old 07-24-2018, 11:54 AM
  #2357
have to run Kyosho wheels almost always for best fit.
rcbuggy88 is offline
Old 07-25-2018, 07:09 PM
  #2358
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
I ran AKA wheels without any problems but that was with the EVO wheels.
Kraig is offline
Old 07-31-2018, 02:31 PM
  #2359
Trader Rating: 32 (100%+)
Can someone tell me what electronics setup is the way to go for carpet. Right now I have motor in the rear with servo in front of it. Battery in rear with esc in front. Should I run motor up front for carpet or no.
kyok2 is offline
Old 07-31-2018, 05:03 PM
  #2360
Your choice. Running the motor in the front will give more steering. I would run the motor in the middle. Rear motor, 8mm forward.
Old 08-12-2018, 08:32 AM
  #2361
oPAULo's Avatar
Anyone know if there is a steel outdrive for gear diffs to run these pucks?
oPAULo is offline
Old 08-12-2018, 08:35 AM
  #2362
oPAULo's Avatar
Also, our other ZX came with ball diffs that has steel outdrives for the pucks. Where do those come from?
oPAULo is offline
Old 08-12-2018, 10:37 AM
  #2363
oPAULo's Avatar
http://www.kyoshoamerica.com/VVC-Gear-Diff-Shaft-Blade2p_p_23525.html
Anyone ever ordered this? The picture is clearly steel outdrives but the description says aluminum.
oPAULo is offline
Old 08-12-2018, 05:58 PM
  #2364
Pretty sure that's aluminum, not steel. Looks like it was originally meant for a TC. Only run this in a stock class.
Old 08-12-2018, 06:00 PM
  #2365
I don't belive there is. Just replace the top outdrives from the picture and also the blades. The warping was probably caused by the worn out blades.
Old 08-12-2018, 06:16 PM
  #2366
oPAULo's Avatar
I've been replacing them. The outdrives are just very old.
oPAULo is offline
Old 08-13-2018, 05:21 AM
  #2367
oPAULo's Avatar
Bulletproof. The hardest part was polishing the surfaces. Should last a good long time.
oPAULo is offline
Old 08-16-2018, 08:12 AM
  #2368
joNathanW's Avatar
Is there any reason why this buggy is so cheap right now compared to others?
Most shops here in Germany offer it for 260 €, which really isn't that much compared to the Associated B64 (390,- €), Xray XB4 (529,- €) or the Yokomo YZ-4SF (500,- €). Even the "little brother", the Ultima RB 6.6 2WD is more expensive with around 430,- €.
Always wanted a secondary buggy, either 2WD or 4WD and this seems like a pretty decent option.
Maybe someone can help me out
joNathanW is offline
Old 08-16-2018, 09:15 AM
  #2369
azeroth's Avatar
Trader Rating: 21 (100%+)
older chassis than others and rumors of a updated version coming but it is a great car I have 2 alittle heavy but perform great
azeroth is offline
Old 08-28-2018, 06:47 PM
  #2370
vikingen's Avatar
Trader Rating: 29 (100%+)
in case it was missed..
azeroth likes this.
vikingen is offline
