Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 02-12-2014 | 10:43 PM
  #1951
Originally Posted by jones8352
I wouldn't use either of those motors if you're serious about racing. I was joking earlier with one of the Tekno drivers and he said the Tekin 2250 has waaaay too much power, high kv motors like that would take serious talent to control. On 4s I would be looking at the Tekin 2000kv if you want to run a truggy motor, it would have gobs of hp and should run cool enough geared properly. The 1550 on 6s I think it would be too much again, that motor would run cooler imo with a 5s battery plus it would be much easier to gear properly. If you really want to run 6s I would go with the Tekin 1350kv truggy motor, now that setup would give cool running and longer run times. than 4s.
As I would be racing from time to time, I would be bashing around with a few friend a fair amount of the time as well. I would split it at a 50/50 kind of a deal. Having said that, I feel like going for 2250 (4s) or 1550 (6s) just because they have higher top speeds at normal gearing compared to their lower kv counterparts. I feel in a choice between 2000kv overgeared for the same speed as a 2250kv on normal gearing, 2250kv with normal gearing sounds like the better option, would you agree? Of course this is just my opinion, and as I said earlier, I do not have a whole lot of knowledge on the matter, so do let me know if im missing something.
between the choice of the 4s vs 6s setup, which one should I go for keeping in mind ill be bashing half the time as well. I havent bought any electronics or batteries yet, so none of that factors in.
mamdot91 is offline
Old 02-12-2014 | 10:48 PM
  #1952
Originally Posted by scorpion51503
Mamdot I'm sorry I missed your question mine runs about 130 in a 10 minute main with a 15 it was running about 145 in 10 minutes I guess I really can't say that I've pushed it really hard cause I haven't ran it in a big race yet but my track requires a lot of braking and throttle for a truggy which generally creates a little more heat so I would say it wouldn't have a problem in any reasonable conditions
Perfect, thank you for the info. you had it geared at a 14t when you got 130 in the main? Either way the temps look really cool which is very promising. I just have to make a decision between a 4s or a 6s setup now.
mamdot91 is offline
Old 02-13-2014 | 05:56 AM
  #1953
8ight-e's Avatar
#1 check your local rules if there are any.. I don't know of anyone who wont allow 6s configs racing now except full on roar events. They are always behind the times.
#2 do you have the means to charge 6s effectively?
If both those give you a green for 6s, remember higher voltage is always better.. less amp draw. This equals happier ESC's and Happier LIPO's over time. Motor temp, and abuse is consistent on any voltage if your are setup properly.
Highly recommend the HW 150a esc, best choice of them all iMO
Highly recommend the Tekin truggy motors
BTW I raced the last three years and have had a ton of success on the tekin 1550kv 6s, you can easily race w/ this config if you are any good at all. Note this was with an 8ight-te so it was easier to gear properly. The ET48 is a bit more limited in gearing options, so the 1350kv does make more sense in this rig, but you can EASILY race w/ the 1550kv motor.
GL
8ight-e is offline
Old 02-13-2014 | 08:54 AM
  #1954
jones8352's Avatar
I think over gearing is never a great idea. If I was in your situation both racing and bashing I would go 4s and have two motors. The 2250 for bashing and a 2000 for racing. When I first started racing I ran a Castle 2200 for one season, good motor but maybe a tad too much power for me at that time. I hear the Tekin 2250 is even stronger. Another factor to consider is the price of packs. I don't buy 6s packs but I'll bet they're more expensive than 4s.
jones8352 is offline
Old 02-13-2014 | 09:00 AM
  #1955
Cain's Avatar
Tech Legend
heck, honestly I don't see how bashing with a 2000Kv motor isn't possible to get the same kind of speed and enjoyment as yo uwould with the 2200 whatever motor.
If the motor can pull the gearing, and the truggies motors can pretty easily at that, I would just settle on the 2000Kv and go from there.
Cain is offline
Old 02-13-2014 | 09:07 AM
  #1956
UK.hardcore's Avatar
Packs are all the same if they have the same overall energy.
UK.hardcore is offline
Old 02-13-2014 | 09:46 AM
  #1957
Extremely appreciate all the detailed responses! I am definitely going with the hw 150a esc. As for the motor I am going to take another day or two to make my final decision. Very excited either way since it all seems like one big green light ahead haha.
mamdot91 is offline
Old 02-13-2014 | 10:37 AM
  #1958
metoo's Avatar
Originally Posted by metoo
However, the engagement length of coupler on the rear diff pinion shaft is longer than the space between coupler's slot bottom and the dog bone (rear center shaft). So it appears its a 9 screw effort, of which 3 have loctite.
...which is what I said concerning removal of the center diff. Come to find out, that's nothing compared to the 21** screws required to remove the servo! Good gravy. I like this thing, but hamburger. It's still less painful than doing the same on a DEX410. On the bright side, I have a new popular brand servo this time, so hopefully it will not need replacement or repair anytime soon.
** if you use all screw instructed and route wires under the ESC.
metoo is offline
Old 02-13-2014 | 10:59 AM
  #1959
jones8352's Avatar
GL
The reason I thought a 1550kv motor on 6s might be too much is I tried racing a Castle 1520 1y 1600kv motor using a 5s pack. It had way too much power, I couldn't even imagine running it with a 6s pack. I do realize that particular Castle motor is real beast, it's huge in comparison. The 1550 on 6s must be a real rocket! LOL
Old 02-13-2014 | 11:53 AM
  #1960
I'll find out soon.
Old 02-13-2014 | 12:13 PM
  #1961
Had a driveshaft break today. Noticed the out drives on the rear are both like this after 15-20 packs thru it. Tekno, please make some harder out drives.
Mullet1 is offline
Old 02-13-2014 | 12:22 PM
  #1962
metoo's Avatar
That's no bueno. Good traction + big tires + aggressive driving = need for hard outdrives. Has this been an issue with the EB48?
metoo is offline
Old 02-13-2014 | 12:47 PM
  #1963
Not even close to the same wear on the buggies
Mullet1 is offline
Old 02-13-2014 | 01:03 PM
  #1964
jones8352's Avatar
I got my eb first batch, I'm still running the same outdrives and they look real good so do the pins on the shafts.
Old 02-13-2014 | 01:43 PM
  #1965
jones8352's Avatar
Originally Posted by UK.hardcore
I'll find out soon.
A video would be real nice!!!
