Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 02-23-2014 | 06:51 PM
  #2101
Originally Posted by jones8352
Steel spurs, yuk! Heavy and noisy! Tekno plastic spurs are awesome, real strong. Keep them adjusted properly and they'll serve you well for a long time, plus lighter running gear should accelerate quicker too.
Quicker acceleration Not really depends on what kv your running im running a tekin 1550 kv motor on 5s and 6s if i want to go crazy power 6s not need it by the way , 5s is more then enough trust me , i run with a bud thats running a tekin 2250 kv truggy motor that he run on 4s hes not any faster then i am and fact on the straight away im just a hair faster also im running cooler do to lower kv , about noise on the steel spur i give you that but when your racing who cares half of the time you dont hear it your to busy racing with the rest of the pack ( racers ) LMAO
mavdriver is offline
Old 02-23-2014 | 06:59 PM
  #2102
jones8352's Avatar
I understand most of the variables, on paper lighter should be quicker but most of our systems are so over powered it really doesn't matter much any more.
jones8352 is offline
Old 02-23-2014 | 10:25 PM
  #2103
Originally Posted by Electric Dave
Two quick questions guys...
1.) What's the recommended pinion for a 2000KV/4S Setup?
2.) Are you guys finding the steel spur a necessary upgrade?
Thank you,
Depending on he track size I run 15 or 16.
Mark
munrath is offline
Old 02-24-2014 | 08:12 AM
  #2104
mechanic_dan's Avatar
Ok I posted pics of my diffs earlier with the old shims and the wear that was happening. Here is a pic of my rear diff (had the worst wear with the old shims) after replacing the shims with Tekno's new ones and a good hard Sunday of racing (5 packs). There is no wear at all and the diff fluid was very clean. Thank you Tekno for doing such a great job at fixing this problem
mechanic_dan is offline
Old 02-24-2014 | 08:46 AM
  #2105
kaisertrip's Avatar
I can verify and testify to the HARD racing as mentioned above!
out
kaisertrip is offline
Old 02-24-2014 | 10:07 AM
  #2106
SirWraithe's Avatar
Originally Posted by scorpion51503
You will save A lot of battery and heat due to less wheel spin
Thanks Scorpion!!
SirWraithe is offline
Old 02-24-2014 | 12:40 PM
  #2107
Hey SirWraithe what tires are you using on your et48?
mamdot91 is offline
Old 02-25-2014 | 07:37 AM
  #2108
JeremyMcG's Avatar
Nothing but kind words for this company. I have a 1st run kit that is fully built but never ran. I contacted them as they said about the diff shims this past Friday. Well I had them in PA Monday morning! Awesome guys!
JeremyMcG is offline
Old 02-25-2014 | 11:26 AM
  #2109
This might sound like a stupid question (Yet AGAIN), but would a HW xerun 150a easily handle 6s lipos? Also, do 6s lipos usually put more strain on the ESC compared to 4s? More number of cells = more stress/heat?
mamdot91 is offline
Old 02-25-2014 | 11:30 AM
  #2110
Electric Dave's Avatar
Well, I ordered one last night! A-Main had them in stock so I grabbed one from there. I emailed Tekno and they have already sent the revised Diff Shims...can't wait to get this beast up and running!
Electric Dave is offline
Old 02-25-2014 | 12:01 PM
  #2111
It will handle 6s but you may need an external BEC. The Built in BEC is a bit weak in those. 6s with a low KV motor (1500kv or so) is very efficient and will be easier on your esc than a low voltage / high amperage setup.
MX304 is offline
Old 02-25-2014 | 12:27 PM
  #2112
JeremyMcG look this page and see my post on the new shims with the picture of my rear diff. I emailed them on a Monday and I had my new shims on Thursday. After five packs through with the new shims I had no wear. Tekno takes care of their customers.
Old 02-25-2014 | 02:30 PM
  #2113
So if you were to keep all other variables out of the equation (such as cost, current chargers/batteries/motors etc) you would go with a 6s setup?
mamdot91 is offline
Old 02-25-2014 | 02:43 PM
  #2114
boudin4evr's Avatar
YES!
If you do not run any ROAR events
I dont think 6s is legal in etruggy
boudin4evr is offline
Old 02-25-2014 | 07:29 PM
  #2115
not really my bud run his on 6s and 5s with no issues mostly 6s by the way so no need for seperate bec only if you are running more then 2 servos thats when you need it , hes only running esc and one steering servo .
