Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 02-12-2014 | 06:02 AM
  #1936
egobrkr's Avatar
Originally Posted by metoo
Must see vid of said ridiculousness.
https://www.youtube.com/watch?v=DkBM...e_gdata_player
His tekno is the white and green one.
egobrkr is offline
Old 02-12-2014 | 06:16 AM
  #1937
UK.hardcore's Avatar
Any one use yellow springs?
UK.hardcore is offline
Old 02-12-2014 | 06:31 AM
  #1938
8ight-e's Avatar
Yellow rear is my base...
8ight-e is offline
Old 02-12-2014 | 08:19 AM
  #1939
jones8352's Avatar
Originally Posted by Cain
has anyone tried running a 1700Kv buggy motor on 4S on the ET48?
Also, anyone fit a Castle 1518 motor on the ET48?
I don't think it will fit without relocating the esc. I think the 1518 is 83mm long, I'll dig one out and lay a tape on it.
The motor is 83.5. the Tekin esc is 40mm wide for a grand total of 123.5. On my kit looks like I have 126mm from motor mount to the servo. So it will fit.
jones8352 is offline
Old 02-12-2014 | 09:21 AM
  #1940
Cain's Avatar
Tech Legend
The motor is 83.5. the Tekin is 40mm wide for a grand total of 123.5. On my kit looks like I have 126mm from motor mount to the servo. So it will fit.
cool thanks for the info!
Cain is offline
Old 02-12-2014 | 12:26 PM
  #1941
Guys I am still debating on a 4s vs 6s setup. Could I get some pros and cons of both the set up below:
4s tekin 2250 vs 6s tekin 1550
People say 6s runs cooler than 4s. I did the math and with the two setup above, the 6s setup has a higher total RPM of the motor ... it was around 34k rpm and the 4s was somewhere in 33k rpm ... Would it still run cooler even if its doing higher rpm? Are there other factors involved that I am not aware off? Im fairly new at this so please do enlighten me!
Also, any pros cons that might swap me towards either setups?!
mamdot91 is offline
Old 02-12-2014 | 01:07 PM
  #1942
Cain's Avatar
Tech Legend
your Kv selection seems a bit high personally.
6S will run more efficiently so you should see an increase in runtime and less heat.
Cain is offline
Old 02-12-2014 | 01:08 PM
  #1943
jones8352's Avatar
I wouldn't use either of those motors if you're serious about racing. I was joking earlier with one of the Tekno drivers and he said the Tekin 2250 has waaaay too much power, high kv motors like that would take serious talent to control. On 4s I would be looking at the Tekin 2000kv if you want to run a truggy motor, it would have gobs of hp and should run cool enough geared properly. The 1550 on 6s I think it would be too much again, that motor would run cooler imo with a 5s battery plus it would be much easier to gear properly. If you really want to run 6s I would go with the Tekin 1350kv truggy motor, now that setup would give cool running and longer run times. than 4s.
Old 02-12-2014 | 02:41 PM
  #1944
At 2:44 I stop and wait for the first time and at 4:52 is when I blow the castle 2200 away with ease
scorpion51503 is offline
Old 02-12-2014 | 04:08 PM
  #1945
jones8352's Avatar
Do you beat the guy driving the 2200 with ease because you had so much more power or was it a matter of you having much better driving skills plus a superior kit? My guess is both, the ET is an awesome kit plus if Tekno sponsors you, hmm must know how to drive fast, real fast!
Old 02-12-2014 | 04:10 PM
  #1946
metoo's Avatar
Are the final drive ratios close to the same? Where both batteries at around the same level of power at that time. As for the waiting, the Mugen seemed to make a lot of mistakes.
metoo is offline
Old 02-12-2014 | 04:32 PM
  #1947
egobrkr's Avatar
I was the mugen and I was in 2nd place most of that race. The truggy that was making the mistakes was a RC8.2 with the castle system in it. I run a tekin 2000kv truggy motor.
egobrkr is offline
Old 02-12-2014 | 06:22 PM
  #1948
Could somebody who got one of these on Tekno military/veteran discounts PM me on just how much the discount was. They have as $599.99 normal price. Thanks
Cody01 is offline
Old 02-12-2014 | 08:22 PM
  #1949
Yeah I wasn't saying he was a similar skill level driver the whole race was more of a screw around race since we only started with 4 and were down to 2 less than half way through I was merely showing how much faster mine was down the straight with my current limiter at 35 I am by no means trying to sell this motor as the way to go for this truggy merely just a comparison of speed down a straight line but being overpowered costs more racers victories than it ever wins them victories
Old 02-12-2014 | 08:42 PM
  #1950
The castle 2200 motor is said to run cool with this truggy? I might be mistaken but werent people saying that the 2000kv t8 would run a little hot with this truggy at 15t gearing? Does that mean the castle 2200 runs cooler than the 2000kv t8?? :/ ... isnt tekin supposed to run cooler than castle products? If I am under the wrong impression about the t8 please do let me know, because I am inclined toward buying the 2000kv t8 but if the castle runs cooler than the t8 then Im not sure how I feel about t8 motors anymore.
Scorpion on the previous page said he runs a 2250 kv t8 ... How is that holding up scorpion? Does it run cool or hot or just fine? A little info would be most appreciated!
Mamdot I'm sorry I missed your question mine runs about 130 in a 10 minute main with a 15 it was running about 145 in 10 minutes I guess I really can't say that I've pushed it really hard cause I haven't ran it in a big race yet but my track requires a lot of braking and throttle for a truggy which generally creates a little more heat so I would say it wouldn't have a problem in any reasonable conditions
