b44.2 AVID chassis.... worth it?
Tell us what you think. Pros. Cons. Anyone that has one, feel free to help us out. The ones on the fence about making the purchase. Is it really worth it, or just a bunch of bling.
The chassis has been out for a week, so the first people should be running them now. I did all the testing and I think that the car has a more planted feel and is easier to drive because it's more stable and predictable. On the site I posted a couple of my setups:
http://www.avidrc.com/downloads/setu...-AVID_Team.pdf
http://www.avidrc.com/downloads/setu...ssis-Coach.pdf
What's the weight difference between avid and stock chassis?
I havent tried the Avid but, I did try an aluminum chassis on my B4. It made the buggy a lot heavier and that caused it to break ALOT more. I dont know if the Avid weighs more but that is something to consider. It did drive well but not worth the extra parts breakage. I am a decent driver too.
Looks like a nice kit, and is reasonably priced. I agree if you have a b44.1 it would be a great way to upgrade. As for the less flex, hmm, not always good. In theory everyone always tries to make a stiff chassis so the shocks can do the work. But in reality of rc cars it is usually better to have flex to make the car have more traction and usually is more forgiving. Aluminum is also prone to denting easily in the milled areas.
As for more steering? Debatable, sometimes more steering just gives the car a twitchy/oversteer feel. Yes more steering, but at cost of forward bite.
arent the top decks the same length between the b44.1 and .2? I thought the length increase was in-between the top plates? (I seem to remember them being the same. it's the "center brace" that got 8mm longer, yes/no?) I think the front/rear plates ARE different when it comes to the holes down the center of the top plates...but the geometry I thought was still the same.
At any rate, after the review by Waflet in the b44.2 thread, I went ahead and ordered the Avid chassis for my son's B44.1. He's 9 and I cringe everytime he cases a jump lolol. I think it will be a great upgrade honestly. We'll see as soon as it gets here!
R/C Tech Elite Member
Here is a write-up from one of the guys at my track. He has spent a lot of time with his mod buggy and understand car characteristics to a very fine point. He whips my butt with his mod buggy all the time
http://www.rctech.net/forum/12144353-post4338.html
Suspended
I have to say when I put the chassis on and went to try it out it was totalllyyy different. I have never added rear weight but used the two weights that came with the avid chassis and it was totally different. The rear end felt a little more squirly and if you didn't stay on top of it you would just slip. After having about 3-4 practices on it I am glad I changed it. Like it a lot better. Great chassis and great engineering from Avid.
I would recommend the AVID 2+2 1.6/1.1 rear pistons also which plant the rear end with a little less low-speed damping in the rear to give you more grip.
For a 44.1 conversion, we priced the AVID +8 upgrade to be the least amount of parts. The AVID +8 set lets you keep the same center cap and center slipper assembly from your 44.1. You can also buy your own 44.2 upgrade parts to make it a 44.2 (center slipper shaft, center cap, 44.2 rear driveshaft, 44.2 top deck, battery trays, battery straps) but the price will be more and it's not all in one package.
