TLR 8IGHT E 3.0 THREAD >
Like Tree2Likes
Old 05-22-2013 | 08:10 PM
  #121
Rockthecatbox21's Avatar
Originally Posted by XXXDad
Who uses the washers in the dif... next to the red o-ring??
Uhhh, i do i guess? Btw it's one washer and pretty much every diff gear i've seen uses something very similar to that. Don't really see how that's an insult or a disadvantage.
Rockthecatbox21 is offline
Old 05-22-2013 | 08:17 PM
  #122
XXXDad's Avatar
R/C Tech Elite Member
Thumbs up LOL
I was asking.... because I built my Dif with them.... and now I'm hearing, not to use. Just feeling around....
XXXDad is offline
Old 05-22-2013 | 08:20 PM
  #123
It's been talked about in the 8ight E thread. Somebody mentioned a how-to video by Adam Drake on how to build diffs where he recommends not using them. Some others have also commented that they don't use them either. Sounds like it gives a much smoother diff action. I haven't tried it yet but will be next time I rebuild my diffs.
SC-Racer is offline
Old 05-22-2013 | 08:47 PM
  #124
Originally Posted by guss2009
How is everyone holding down there tekin Rx8 speed control? Are you guys using double side tape? I also don't know where to hold the on/off switch. There's no instructions on how to install this.
Originally Posted by Rawwolf
I use the Kyosho gel in my scte. It is about 1/4 in thick and gives the speedo a little cushion. It is pricey at 14 bucks for a package but it is reusable if you get it off clean. Just clean it with alcohol and it gets sticky again. I have seen alot of people use reg servo tape and stick it to the side of the speedo.
Its great stuff. Kyosho Gyro Tape part number Z8006.
Once you stick it its there but can be pryed up easy and is reusable. Really dampens the hard knocks and vibration.
SixxGunnz is offline
Old 05-23-2013 | 03:49 AM
  #125
XXXDad's Avatar
Lightbulb With the RX8
I use a ziptie and a dot of shuegoo to hold the switch.
XXXDad is offline
Old 05-23-2013 | 05:08 AM
  #126
pballer2777's Avatar
in the nitro section casey peck does a step by step with pics on the build. he does not use the washers. he says make the diff smoother. i did not use them in my build.
pballer2777 is offline
Old 05-23-2013 | 06:43 AM
  #127
I don't even know what's right anymore. So confused.
Old 05-23-2013 | 02:52 PM
  #128
XXXDad's Avatar
Cool Teknotarded
Hahahah im messin with you Rock
I will take mine out the middle dif.... I went 5/5/3 and think I will try 5/7/3 with the 1900 it feels a little less punchy than the 2050 I ran before. Need to experiment..
XXXDad is offline
Old 05-24-2013 | 09:03 AM
  #129
-WHEELMAN-'s Avatar
Im running 5/5/3. To me it was less pushy and easier to drive hard than 5/7/3! Large size medium bite indoor.
-WHEELMAN- is offline
Old 05-24-2013 | 02:55 PM
  #130
Originally Posted by MattP
I honestly don't see the 3.0 as being some big upgrade from the 2.0 at all. I bet the 2.0 guys will run with it no problem.
I have to say I would have agreed with you until I drove the two...
It is a huge difference between the two. The shocks were completely redone in a bigger bore with new O-rings, machined spacers and machined pistons and new springs. The vehicle comes with the upgrades you would want to run. The new caster blocks and spindles give a ton more steering and steering throw you need the new front arm to use those. The towers are taller to get the right up travel versus down travel which this car has a ton more of both. The chassis flex being what it is now is much better as well.
Just my .02 though.
hacker07 is offline
Old 05-24-2013 | 04:00 PM
  #131
XXXDad's Avatar
Thumbs up It drives like a dream...
Just my .02 though.
New Ink> I tryed this new Paint Job out .... Not easy to airbrush.... Now let's cut it out and see how it fit's.
XXXDad is offline
Old 05-24-2013 | 07:53 PM
  #132
1badgoat's Avatar
Just my .02 though.
+1
I tried to say the same thing. Maybe people will listen a little more hearing it from you.
1badgoat is offline
Old 05-25-2013 | 04:28 AM
  #133
XXXDad's Avatar
Cool Its our seacret...
Originally Posted by 1badgoat
+1
I'm happy if i am the only one with a 3.0...... its like cheating. Feels like an advantage. Very good car, like a wolf in sheeps clothing.
XXXDad is offline
Old 05-26-2013 | 05:34 AM
  #134
ChrisWolfson's Avatar
Ran mine yesterday. Definitely recovers in the jumps and rough stuff when you "get it wrong" better than the 2.0 did. The car is much easier to drive than my 2.0 was. I had a great time running my car yesterday.
ChrisWolfson is offline
Old 05-26-2013 | 06:21 AM
  #135
XXXDad's Avatar
Thumbs up
What setup did you start with chris>> Mine is
Front shock 32.5
Rear shock 27.5
5/5/3
the rest was Drake settings.
XXXDad is offline
