TLR 8IGHT E 3.0 THREAD >
Like Tree2Likes
Old 03-13-2016 | 12:20 PM
  #3661
how did he have it mounted? did he not have the side guard on the chasis? I know on mine with three bolts in it its solid as a rock with no way for the unit to move.
rotor head33 is offline
Old 03-13-2016 | 12:23 PM
  #3662
maddog9's Avatar
Originally Posted by platgof
Maddog9 thanks for the setup. My friend ate the side of a battery with the battery forward. Is there a safe, secure, way to mount it?
So looking at picture in this view front of the car is at the top of the picture. Keep the orientation of the tray the same. You will want to trim the frontal inner lobe off until you can fit next to the front brace. You will be able to get the screw into the front most side gaurd hole when you take enough material off. The other spot you will have to trim is right next to the center diff. I believe the rear most inner screw is the only otger existing screw. The rest of the holes you will have to drill and tap the holes to make sure the tray is properly held to the chassis. Hope this helps!
maddog9 is offline
Old 03-13-2016 | 12:25 PM
  #3663
im glad you posted that maddog I was curious how I was going to run my esc wires! I was gonna use braided sheathing over the wires and run them up over the center diff but that is MUCH nicer!
Old 03-13-2016 | 01:34 PM
  #3664
maddog9's Avatar
Yes notch the under part of the battery tray so you can run it under the battery and run it under the front chassis brace. This way it will avoid any worries of getting it caught in the spur gear or in the driveshafts!
maddog9 is offline
Old 03-13-2016 | 07:15 PM
  #3665
platgof's Avatar
Good to know that. I get the kit tomorrow and will start work on it then. I guess the battery forward is a must do? Wasn't it forward on the 2.0?
platgof is offline
Old 03-13-2016 | 07:56 PM
  #3666
maddog9's Avatar
Yes the 2.0 was forward and i think it is a must on the 3.0. I am running the battery forward on the 4.0 as well.
maddog9 is offline
Old 03-13-2016 | 10:15 PM
  #3667
We have a center diff that keeps breaking. On the first run of the car it ran fine for half a battery, then something gave and slowly progressed into no power (vs. less power) to the wheels.
We took it a part and inspected it. No issues that we could see. Added new 5k weight oil and put it back together per the manual.
Got back out and ran great for a battery. Then, a few minutes into the next battery the same thing happened.
This is on car 1 of 2 we just built, and car two is having no issues.
Can anyone give us an idea of what's going on? We are kind of scratching out heads...
pdxrealtor is offline
Old 03-14-2016 | 02:41 AM
  #3668
How many people actually run the fan on the rx8 gen 2 Esc?
Old 03-14-2016 | 03:43 AM
  #3669
maddog9's Avatar
I run it just in case. I am usually at 90F on the esc when i pull off.
maddog9 is offline
Old 03-14-2016 | 04:33 AM
  #3670
Ok cool. I was just curious. Im putting mine on.
Old 03-14-2016 | 10:43 AM
  #3671
Casper's Avatar
Are you sure it is the center diff? I would check the entire drive train. All your set screws on the center drive line. Seems odd what you are stating. When you rebuild the center diff is it still full of fluid?
Casper is offline
Old 03-14-2016 | 11:07 AM
  #3672
thirtydaZe's Avatar
Delete - wrong thread.
thirtydaZe is offline
Old 03-14-2016 | 02:26 PM
  #3673
Yes, because I can hold the spur gear and roll the car with the drive lines attached. I did a visual check for the front and rear set screws as well.
The first time it happened the center diff did leak some oil but it wasn't evident where it was actually leaking. We haven't taken it back out yet, and didn't notice any oil while cleaning it up.
Old 03-14-2016 | 03:12 PM
  #3674
pballer2777's Avatar
anyone running the battery forward mod only using 2 screws in the battery tray? seems pretty solid. i dont have a tap to make new holes.
pballer2777 is offline
Old 03-14-2016 | 04:17 PM
  #3675
Casper's Avatar
Did you take the sun gears out and check the outdrives and pins.
It is pretty odd to have a failure like this and not see anything broken and have it go back together and work for a short period again. With the power we put through these things, stuff usually either works or its broken.
Casper is offline
