TLR TEN-SCTE 2.0 Kit Thread
#6438
Sorry to hear about your house. Don't know about your budget, but here goes...
Seems the most popular electronics are (in no particular order):
ESC
- Tekin RX8 (Gen 1 or 2)
- HobbyWing Xerun 120A SCT Pro
- Orion R10 Pro
- Castle Creations Mamba Max Pro (but may need a separate BEC)
- Viper (otherwise someone will complain if I leave it out)
Servos (not as much concensus here...)
- anything with over 180oz torque and under 0.15sec speed
- Savox 1256TG, 1257TG, 1258TG
- Radiopost Green (haven't heard much about this on the 2.0 thread, but there was a while that the 1.0 thread had good news on this)
I'll stay out of the motor debate, but if you look over the last 20 pages you'll get some ideas of 2 pole vs 4 pole, Hobbywing / Tekin / Orion.
Hope this helps,
ESC
- Orion R10 Pro
Hope this helps,
#6439
hi guys
so i turned the lvc down to 3v and it got i little better so then i tried 2.8v and it got better again YAY...
then i saw that the motor shaft has 1mm of movement in and out of the motor and when i push it into the motor with my finger on the rear of the motor i can feel it touching the rear of the motor. should there be any movement there?
my mate at work has the same motor/ esc combo and i had look at his and his has no movement in the shaft at all. could this be the problem, maybe somthing has broke internaly and is disrupting the sensor?
#6441
Kingsheadz Center Diff Mount Install
Purchased the Kingsheadz Center Diff Mount for SCTE and have a BCE H1 chassis. The mount has an additional third bracket leg requiring me to drill an additional hole in chassis to utilize this extra support. My question is, has anyone mounted this piece on a BCE chassis and if so what was use to drill out the third countersunk hole? And also, is this necessary or could I just use the two that normally mount it to the chassis? Thankyou!
#6443
ESC
- Orion R10 Pro
Hope this helps,
ESC
- Orion R10 Pro
Hope this helps,
Yea thanks and thanks for the help
#6445
#6446
#6447
TEN-SCTE 4WD REAR DIFFERENTIAL in 2.0?
I could not find a definite answer on this question. If I purchase a complete LOSI TEN-SCTE 4WD REAR DIFFERENTIAL will it directly fit/mount into the scte2.0? Is there differences I should be aware of? Looking to have as a backup/different setup.
Thank you
Thank you
