TLR TEN-SCTE 2.0 Kit Thread
#6586
1. are they on opposite sides of the servo? (long ways). I would like to see all 4 in there and I find it off it does not fit. what exact servo you putting in there? Servo's tend to be pretty std.
2. Just different batches of anodize. I would not be concerned at all.
3. Again plating process can effect finsih. I would not be too concerned.
The servo is ko rsx response hc, I can fit two holes that are on the same side (I chose the two near the servo horn to resist the torque better). The holes on the other side are about 2mm too far out; I can make a picture tomorrow. I was pretty surprised as I thought the same, standard size servos have the holes at the same spot.
Happy to hear that the other two issues are just cosmetic differences!
#6587
Thanks for the quick reply Casper!
The overall specs are not too far off other then those appear to be tall (at least the way we install it in the SCTE).
They are on the long side of "std" but it should fit. You can't get the 4 screws started and then tighten them down?
#6588
Has anyone dropped the 50 bones on this new caster block??
http://www.horizonhobby.com/products...scte-TLR334017
Curious how much more steering this offers? What is the stock caster block angle compared to this new 15* option?
#6589
shock building problems
Hey guy,
I'm having problems with my shocks on this kit. I fill them up and let them sit for a while to get all the air out of them, but when I put the caps on and pull the bleeder screw out and push the excess oil out, and screw it back in the shock will have reverse rebound, the shock shaft sucks into the shock. I've watched a bunch of videos on YouTube and I'm doing it the same way that they are but no matter how many times I try it has the same result. Any ideas on what's going on?
#6590
Hey guy,
#6591
1, the servo mount has fixed positions between mounting holes, so do my servo (ko rsx response hc) and only two of the holes match. Is it OK to only use two screw to mount the servo or is there any mod to the mount? I want to avoid trimming the servo case if possible.
2. the front shock bodies are darker than the rest of the aluminum shock parts, is it reason to be concerned?
3. one of the turnbuckles has a different finish from the others; it is satin and a bit darker. It seems to be the same size; is it somehow substantially different?
What I would suggest is that you tap all the servo mount holes first, with the screws provided, or with a 4-40 tap. Do this without your servo in the mount at all. After you've pre-tapped the holes, it becomes a little easier to get the screws in, once the servo is positioned.
Start the screws at one end of the servo. Front or rear - it doesn't really matter. Get a few turns on the screws so they are halfway engaged or more, but not so far tight that the heads are pinching down on the servo ears. Then gently push your servo as far as you can to gain access to the holes for the screws at the opposite end of the mount. The plastic mount will flex just a little. Start those screws, and then snug them all up evenly, till they are tight.
As for the color differences in the aluminum shock bodies, and the turnbuckle, I would not be concerned at all. The color difference is probably due to a batch of parts that weren't in the anodizing tank as long as some others, or in the plating tank.
#6592
#6593
Hey guy,
#6594
Yeah I would not be happy with two screws on the same side. Must be the closed ends those servo's have?
I am afraid if I oval out all the holes the remaining material in the mount will become too thin.
#6595
Height is allright, it fits with more than enough space to the chassis, but now I have compared it to the old airtronics it had replaced in the 1.0 and it is longer by almost 2mm, as you can see in the pic, it is off by about that amount, half the diameter of the hole.
Sadly a little flex will not be enough.
Thanks for confirmation!
#6596
#6597
Hi all need some help, I am having a problem with my car for the last two races is starting to cut out around the 5 minute mark in a 7min race. I still have steering but no throttle. After about 10 sec I have throttle back but it keeps cutting out on any heavy throttle. Temps are - Motor-117, ESC-123, so not a thermal problem (I think). I am assuming it is the battery, hitting the battery cutoff, but this is only a recent occurrence. I have already reduced gearing from a 14 to 13 with no effect. Running a large outdoor 1/8 track.
RX8Gen2, 4600Pro4, 13-40, 6000mAh 65-130C Nano-Tech.
ESC Settings - 2S, LM 80, TP3 - would reducing the current limit help?
Cheers
Cheers
#6598
Cheers
Cheers
#6599
Cheers
Cheers
#6600
