Team Associated B4.2 Thread >
Like Tree4Likes
Old 01-03-2014 | 09:12 PM
  #12136
Cridd's Avatar
I replace my diff every few months. My 17.5 is real noisy right now, pushing and real hard to read on turns. Going to rebuild diff and slipper......and check motor plate.
Cridd is offline
Old 01-04-2014 | 08:29 AM
  #12137
Checked ubrace, all tight. Any other thoughts?
tacticalbacon3 is offline
Old 01-04-2014 | 08:36 AM
  #12138
Suspended
The drive gear makes alot of noise if it gets worn!
theblitzkidd is offline
Old 01-04-2014 | 02:18 PM
  #12139
weyant's Avatar
Well I always tell guys to play with there anti-squat I run ZERO in mine. so if your running 2 or 3 take it out and try that. if your still spinning out or pushing. Ride height can have something to do with that too so play around with that.
weyant is offline
Old 01-04-2014 | 02:22 PM
  #12140
weyant's Avatar
when you say "drive gear" do you mean the top shaft gear?? that's something I haven't replaced EVER lol
weyant is offline
Old 01-04-2014 | 02:36 PM
  #12141
bigdaddy13's Avatar
Originally Posted by weyant
Ok now this is interesting. I got a noise in my sct that I just cant figure out sounds like a squeal and I have gone over that thing so many time and just cant find it. I thought it was something with the gear mesh or trans bearings or drive bearings lol so that might just be the prob? ive been running this sct for 2 year and there have been LOTS of crashes
If it's not constant,it's probably not the motor plate.. A bent motor plate will be noisy all the time,not just when you take off or slow down.
bigdaddy13 is offline
Old 01-04-2014 | 02:43 PM
  #12142
Kurtsara's Avatar
So how do you set or adjust the anti-squat?
Kurtsara is offline
Old 01-04-2014 | 03:06 PM
  #12143
Shims/fr hingepin holder
lee111m is offline
Old 01-04-2014 | 03:19 PM
  #12144
weyant's Avatar
anti-squat is the shim under the rear arm mount and above the rear chassis plat
weyant is offline
Old 01-04-2014 | 04:28 PM
  #12145
FantomLeopard's Avatar
Hey, I tried looking for the answer to this in here but after a couple different checks in the search function I couldn't find the answer:
Which of the servo horns is the right size for a Protek R/C servo? It's this one right here:
http://www.amainhobbies.com/product_...tal-Gear-Servo
25 tooth. I'm either forcing it or doing something wrong because I can't seem to figure out which one -.- I've been using an aluminum one from Protek but I realized that my car didn't turn as far to one side as it did to the other because the aluminum one was a little too long.
BTW, this servo is AWESOME! No issues with it and goodness it's fast! Which is what I need since you have to steer through all the Shortbus traffic at my track
FantomLeopard is offline
Old 01-04-2014 | 04:41 PM
  #12146
weyant's Avatar
Well 25 tooth is what you want and the plastic one from associated is Letter F so if it doesn't fit you may have messed the splines up on the servo
weyant is offline
Old 01-04-2014 | 05:04 PM
  #12147
Jerm13's Avatar
+1 on the above. I know when I installed my Ace, it was a really tight fit to get the horn on. I had to double check to make sure I was putting the right one on.
Jerm13 is offline
Old 01-04-2014 | 05:10 PM
  #12148
weyant's Avatar
well the prob with the aluminum horn is if you didn't use the right one or if you don't have it lined up right and you tighten it down it can screw the gear on the servo up
weyant is offline
Old 01-04-2014 | 05:17 PM
  #12149
perfect I made sure not to try too hard because I didn't want to mess up the servo OR the horns so everything should be fine Thanks for the help guys!
Old 01-04-2014 | 08:38 PM
  #12150
Cridd's Avatar
What is the best way to know if you need to rebuild your diff?
Cridd is offline
