Team Associated B4.2 Thread >
Like Tree4Likes
Old 12-19-2013 | 08:04 AM
  #11926
Originally Posted by Matt Trimmings
If you are using the MIP Pucks then you have to use their thrust. It is designed to fit into the outdrives a certain way.
good to know,thank you.
Subwire is offline
Old 12-20-2013 | 01:04 PM
  #11927
do the MIP Pucks work with a mod motor? or does the power blow them apart?
McC Luke is offline
Old 12-20-2013 | 01:06 PM
  #11928
Blow them apart.
xTotalghost is offline
Old 12-20-2013 | 03:15 PM
  #11929
Afun's Avatar
What do you guys think about the Jconcepts Finisher body b4.1 + 8mm for the b4.2. It's the best seller on A main. Has kind of a forward cab look to it, but nt as forward as the proline bulldog.
Afun is offline
Old 12-20-2013 | 03:32 PM
  #11930
Jstall7543's Avatar
The puck system would probably be fine down to 7.5 but you would always have to remember it's in there. The mip components are really high quality and fairly beefy yet very light. If your a very smooth driver they will probably hold up just fine. Where I run my c4.2 (medium/small indoor clay track) I had a X12 7.5 in there and switched to a tekin gen 2 17.5 and my lap times were 2 tenths slower with a stock motor. The pucks will probably wear quicker with a mod. I'm a pretty smooth driver and I try to never spin a tire on my 2wd buggy. Worst case scenario you will waist $70 but once you experience the lighter feel more nimble of the buggy you might find a mod motor isn't necessary. Especially with the weight savings.
Jstall7543 is offline
Old 12-20-2013 | 03:38 PM
  #11931
Grasschopper's Avatar
Originally Posted by 1967Typhoon
Found my problem with the servo link. The previous owner had the links too close together, which was putting too much pressure on the cups. The manual clearly says to keep a 2mm gap there.
That was me...my bad. That said I'm not sure why I had it that way, the B4.2 I still have is at about 1.5mm (I checked after you pmed me). Honestly I don't remember it binding though.
Grasschopper is offline
Old 12-20-2013 | 04:09 PM
  #11932
ryanpatrickgore's Avatar
Dion Dennison runs the pucks with his 8.0 reedy and loves em. no problems
ryanpatrickgore is offline
Old 12-20-2013 | 05:53 PM
  #11933
any body running the j concepts hd ball cups i need some close messurements i cant for the life of me get the front end to come out right.
ashxxx is offline
Old 12-20-2013 | 06:01 PM
  #11934
Can you be more specific, ash? What are you having trouble with?
C.Borgia is offline
Old 12-20-2013 | 06:03 PM
  #11935
toe and camber seems like do 1 side then the other side out of whack then back and fourth.
ashxxx is offline
Old 12-20-2013 | 06:56 PM
  #11936
After each adjustment, even after a half turn I always make sure to lift and drop again.
lee111m is offline
Old 12-21-2013 | 07:20 AM
  #11937
CHIZZLE's Avatar
Why would you want to? It's mod, save your money.
CHIZZLE is offline
Old 12-21-2013 | 06:43 PM
  #11938
Bcholka's Avatar
So......going to replace the ball cups/ball studs to eliminate some slop---is the latest consensus that the JC ball studs along with the Losi ball cups are the BEST way to go?? Also--part numbers??
Thanks and Merry Xmas!!!
Bcholka is offline
Old 12-21-2013 | 08:45 PM
  #11939
harold56's Avatar
https://www.facebook.com/TeamAssocia...863114166864:0
Could be interesting!
harold56 is offline
Old 12-21-2013 | 08:58 PM
  #11940
rpm ends and stock studs work great for me.
gotta like area 51. Love all the people that "know" what it is too. I'll pick the b5 side haha
lee111m is offline
