Team Associated B4.2 Thread
#7666
yeah, if I ever need a little more steering, I put whites in the rear and check ride height. I have tried many fronts and prefer the greens in the front. Are you running on outdoor loose? I found that 32/30 just didnt have enough pack for me. it was ok, just didnt like the feel
#7667
it feels different. pack vs low speed dampening vs plushness. If all you ever needed to do was change oils, there would only be 1 set of pistons available. When ever you buy a used roller, you should always take the shocks apart. Check the pistons, the amount of limiters and replace the oil. You need to know your car inside and out, so you know where you are and get to where you want to be. I have had several guys at the track say my car is pushing or it feels unstable. Then, I ask, what is in your shocks. Several will say, "I dont know". At this point, I normally giggle, wish them luck and suggest they open up the shocks when they get home. I often buy lightly used kits because of the cash saving and the chance of getting tires that work at my track for cheapish. But, I tear it all the way down, check for stripped screws, rebuilt/set the diff, check out the shock package and look for worn parts in need of replacement. If it is a kit I have never owned before, this also lets me get a feel for how the car goes together and how to fix it. Plus it can highlight what tools I need for the car. i.e. the Kyosho shock tool is trash and best to replace.
#7668
they probably put in some of the most challenging layouts. That far left double as the camera facers is harder than it looks. There is only a 6 inch hump to downside on. Too fast and miss it and you slide into the wall, too slow and rear wheels catch and you flip. Rook me about 5-6 packs to start getting the speed right, but then once pressure was on me, I started miss timing it, lol. I finished 5th and qualified 6th. The winner was Humpty Helms a local sponsored driver. he was in the all orange.
The humming and singing and back and forth b/t the girls cracked me up, precious.
#7669
yeah, she was running the camera. Yeah, hump was the only one doing it double, double triple in 17.5. In 13.5 and mod they did it no problem. Yeah, not sure why the main was 6 minutes. 13.5 ran for 10 minutes......I figured we would at least get 8 minutes...
#7670
I raced my B4.2 for the first time this past weekend.
TQ'ed by a lap. While running in 1st with a quarter track lead... lap traffic. Got tapped coming off of a pretty decent sized jump and broke a front arm. 1/10 cars are not made for 1/8 tracks!
I have never driven a better handling, easier to work on, or faster car than the B4.2 in complete stock form. Factory Team setup to the T and I could not be any happier.
Has anyone had any front arm breakage problems? I broke one in practice after a large 25ft double, and one in the main. I have lost my ability to drive smoothly at all times after a year hiatus from 2wd buggy.
I'm planning on boiling my next set of arms.
#7671
rpm is releasing front arms for the b4. But yes, the b4 drives very well, but dont hit things, lol. It really does not like pipes at a decent clip. That being said, I smacked a few pipes last weekend and nothing broke...now that I said it, it will break next weekend for sure.
#7672
My question still stands: what feels different between "pack vs low speed dampening vs plushness"? I'd be happy to read about it if anyone has a valuable link
#7673
You focused on the wrong part of my post. To clarify, I did take my shocks fully apart to verify and rebuild everything. I have two-hole pistons, the only thing I was unable to do is measure those holes accurately. Maybe they're 1.5, maybe 1.6, I don't know. I decided to use them as is for now, as I'm not good enough to be able to tell the tiny difference.
#7676
I'm planning on boiling my next set of arms.Normal to break something if you hit hard , good news is you will break fewer parts as you gain experience ...
#7678
GOOD GOD I HOPE HE DOESN'T GAIN MORE EXPERIENCE!!!! He's already one of the fastest guys in the south east (look at the AMS 4.0 results for proof). This weekend will give you all the practice you need to get rid of those bad sc10 habbits w/o having to worry about braking anything except an idler gear (loosen the slipper, A BUNCH
). I assume your coming to win some money in ebug & bringing the the b4, right?
#7679
#7680
my latest b4.2 video:
Everyone is talking about weights today, so I'll ask...What handling characteristic do weights modify? I've never tinkered with them and have always had my electronics in the typical locations for each of my cars.
| + YouTube Video | |
4Likes
