Team Associated B4.2 Thread >
Like Tree4Likes
Old 01-23-2013 | 01:17 PM
  #676
ryanpatrickgore's Avatar
yes, good tip.
i also put ock tight on the threads each time i remove it for about 4-5 times, then it builds up a layer on there and it will hold the nut on no prob
ryanpatrickgore is offline
Old 01-23-2013 | 01:23 PM
  #677
Wild Cherry's Avatar
Tech Legend
For those who insist on using a VTS slipper ....
A performance Tip:
More important to add the extra pad & go QUAD. Allows even finer adjustment & stays more consistent then the 3 pads alone....
Wild Cherry is offline
Old 01-23-2013 | 01:28 PM
  #678
Cain's Avatar
Tech Legend
will give trying the VTS will the spring I have now a try then. run on carpet so will be run at tighter settings anyway.
Cain is offline
Old 01-23-2013 | 02:06 PM
  #679
Razathorn's Avatar
Our experience at our track with big jumps and short take-offs that require oodles of punch is that the VTS holds up dramatically better than the avid. Even some of the avid sponsored guys run the VTS here because the triad has simply melted down on them in short order. That was our experience with it. Most run with the standard 3 pad vts setup as well. It's not insistence as much as experience and longevity.
Razathorn is offline
Old 01-23-2013 | 02:15 PM
  #680
curious as to how you guys set the VTS. I usually run my slipper so the front wheels barely pull off the bench when I do my bench test. Are you guys finding that you like running the VTS tighter?
Bob Barry is offline
Old 01-23-2013 | 02:46 PM
  #681
Oceans41's Avatar
AMain originally had the 4.2 arriving today (1/23) but is still showing as "pre-order". Does anyone have any insight as to when exact availability will be? Or shall I assume within the coming weeks and be patient?
I guess I'll be patient
Oceans41 is offline
Old 01-23-2013 | 02:48 PM
  #682
redskins's Avatar
My local Hobby shops/Tracks said this coming week they ship.
redskins is offline
Old 01-23-2013 | 03:59 PM
  #683
Wildcat1971's Avatar
So I have been running the BB shocks for a few weeks now. I was hesitant to buy them because I thought they might be useless. They in no way made my laps faster and thus far ,my lap times are more inconsistent than ever. But I think that is due to the fact I need to retune my car, as it is completely different. Overall I give the shocks an A+ so far. No leaking, no air inside and the buggy is sooooo plush. Like driving on pillows. Now I just need to get the added steering under control and it will be like butta.
Wildcat1971 is offline
Old 01-23-2013 | 04:28 PM
  #684
Cridd's Avatar
You only need to purchase
C hub
Carbon U brace ( shaved)
12mm BB shocks
0 degree blue rear hub
carbon front arm
b44.1 rear arm( carbon rear for high traction)
AVID Steering & Triad slipper
Dont forget the soft spring kits for the shocks otherwise the shocks don't workie. hehe.
Cridd is offline
Old 01-23-2013 | 04:46 PM
  #685
Cridd's Avatar
For you B4'ers, go 49'ers,
serious note, all my shocks on our cars where a little loose about 1mm on the upper mount. I ended up using a 1mm spacer and a nylon nut to tighten up instead of the stock black plastic nut that turned and didn't tighten and this got them tight on the top. Is this right, they should be tight not wiggle, wiggle?
Cridd is offline
Old 01-23-2013 | 04:54 PM
  #686
B.A. Racer's Avatar
The caps should wiggle a little bit. If they are too tight then it will bind and not function correctly.
B.A. Racer is offline
Old 01-23-2013 | 05:38 PM
  #687
+1 dont bind the shock caps.
Old 01-23-2013 | 06:37 PM
  #688
Cridd's Avatar
I'll back the nut off for a little movement, Thank you!
Cridd is offline
Old 01-24-2013 | 12:17 AM
  #689
Tech Legend
Bob most I know set the slipper by hold the wheels & blip method .
I like the nose to raise 2" to 3" max ...
either type slipper set the same way ....
Old 01-24-2013 | 04:29 AM
  #690
NICEALLDAY's Avatar
last week they had it listed for feb 1st.
NICEALLDAY is offline
