Team Associated B4.2 Thread >
Like Tree4Likes
Old 06-15-2013 | 07:45 AM
  #6181
t0p_sh0tta's Avatar
Yes. I think I was running 74/23 with my 9.5. Drop to a smaller spur gear, and check temps every 3 laps.
That thing must not have had any top end.
t0p_sh0tta is offline
Old 06-15-2013 | 07:57 AM
  #6182
PIIHB!'s Avatar
Thanks for the gearing suggestion! I'll try that and I'll get a cooling fan for the esc.
PIIHB! is offline
Old 06-15-2013 | 08:31 AM
  #6183
PIIHB!'s Avatar
Any suggestions for gearing a 13.5 motor?
PIIHB! is offline
Old 06-15-2013 | 09:01 AM
  #6184
t0p_sh0tta's Avatar
The ESC shouldn't need a fan with proper gearing. For 13.5 there will probably be ~2 difference on the the pinion.
Old 06-15-2013 | 09:38 AM
  #6185
thecman26's Avatar
R/C Tech Elite Member
Originally Posted by Skillz_B
Wasnt the D3 banned by ROAR? I would go with either the LRP X20 or Reedy Mach 2, I asked before I perchased a motor, and they were by far the favorites. I ordered the LRP Flow Compeetition ESC and X20 17.5t Combo, just waiting for them to get here.
Actually it is the D3.5 that was banned by ROAR.
The D3 is allowed. I have the 3.5 and yeah it is like cheating! But it your track doesn't care about ROAR rules run whatever you want!
thecman26 is offline
Old 06-15-2013 | 11:06 AM
  #6186
Skillz_B's Avatar
Thanks for the clarification, our track follows the ROAR rules closely so no 3.5, I was going to get a Reedy Mach 2, but I saved $20 by picking up the LRP Flow ESC & X20 17.5t Combo. I will pickup a Mach 2 if I feel like I need it, but I dont think I will.
Skillz_B is offline
Old 06-15-2013 | 11:24 AM
  #6187
Rcmart has rhe speed passion combos on sale
129 dollar for a reventon pro esc and a speed passion motor is not bad
mihaelbencek is offline
Old 06-15-2013 | 02:06 PM
  #6188
kdub's Avatar
Originally Posted by PIIHB!
Hey guys I'm running a 9.5 3.0 Speedpassion motor geared 81/23 (IIRC) with an LRP spin esc (not the pro). My esc was shutting down after 6 minutes of the 10 minute main due to heat. Is my gearing off? Its a medium sized clay outdoor track. The motor was just barely warm.
BTW I upgraded to the AVID clutch. Huge improvement.
That speedo is rated for above 9.5 turn, you are probably putting too much load on it. You might be able to keep using it by going down 1-2 teeth, but I think you're probably geared correctly. Also try keeping the timing low.
http://www.lrp.cc/en/products/electr...egler/details/
kdub is offline
Old 06-15-2013 | 10:33 PM
  #6189
+1 -- this was the point of my post. The D3.5 is obviously faster than ROAR approved 17.5's I have seen and it is no longer ROAR approved. I did follow the investigation some but I don't need to think about the details when you see how the motor performs on the track.
And since our local tracks allow them they are quite popular.
34x17 is offline
Old 06-16-2013 | 07:30 AM
  #6190
Cridd's Avatar
Trying the 17.5 maxilla for fun, will see how it does in 17.5 blinky compared to Mch 2
Cridd is offline
Old 06-16-2013 | 07:33 AM
  #6191
Suspended
For 13.5 I run about 72-31/32 depending on temps.
Team G Racing is offline
Old 06-16-2013 | 07:48 AM
  #6192
Cridd's Avatar
I run a 72/30
Cridd is offline
Old 06-16-2013 | 01:27 PM
  #6193
Got a radio on the way and heading back to the track after a long layoff. Excited to get back to it. Build was about the easiest I have ever had in over 25 years of racing.
DG Designs is offline
Old 06-16-2013 | 08:36 PM
  #6194
Questions?? Gap Gear Cover
I find it hard to believe that it's from a crash, but I've got a big gap at the top of my gear cover on my B4.2, and a sizable one on my T4.2.
I ordered new RPM coveers, thinking it was the AE covers that were junk, but alas...I've come to the conclusion that the ALUMINUM FT MOTOR PLATE is BENT!!!
My thought is to replace them, but wanted to hear from you guys if it's happened to you. I even considering warping from heat but figured, no way.
I see that some guys have switched to a solid plate...hmmm...
CaptainGizmo is offline
Old 06-16-2013 | 08:52 PM
  #6195
57TURBO's Avatar
Had it on two cars. The machined grooves make plate weak.
57TURBO is offline
