Team Associated B4.2 Thread >
Like Tree4Likes
Old 05-13-2013 | 07:57 AM
  #5116
Wildcat1971's Avatar
Sold off the RB6 and going to stick with the b4 until the b5 comes out. The rb6 was a very nice car, but I like you guys more, lol.
Wildcat1971 is offline
Old 05-13-2013 | 08:03 AM
  #5117
Originally Posted by H4rM
speaking of lite-weight, what items are available for the B4.2 to lighten the rotating mass of the transmission?
MIP Topshaft -8
Avid Triad -7
Precision Pinion - 4.8
Total -19.8 Grams
chevmaro is offline
Old 05-13-2013 | 08:04 AM
  #5118
is the triad -7 over the vts or the v2?
Old 05-13-2013 | 08:10 AM
  #5119
Can you make a quick comparison between the two? From what I've read so far, Rb6 is clearly superior to B4
Toyman is offline
Old 05-13-2013 | 08:17 AM
  #5120
VTS. The V2 is the lightest.
chevmaro is offline
Old 05-13-2013 | 08:23 AM
  #5121
hmm, I will weight my avid and v2 tonight. I though someone said the avid was still lighter than the v2. The vts is just silly for 17.5. way too heavy. Hartson ran the v2 at the last stock JC national race. Its always interesting to see what they chnage on their cars when the drop down to stock after running mod. A lot of the stock guys here look at the pros setups and try to emulate them in the stock class.
Old 05-13-2013 | 08:28 AM
  #5122
mingoglia's Avatar
Wow, are you running it that light for 17.5? I know for 13.5, that would be hard to drive at that weight.
Yup, I should have mentioned that it's for 17.5. When I ran 13.5 I had the ballast weight as well as 21g extra (7g next to receiver and 7 g in each triangle).
mingoglia is offline
Old 05-13-2013 | 11:11 AM
  #5123
j.d.roost's Avatar
Is anybody running their 4.2 on indoor carpet?
I did not see any setups posted.
There are quite a few 4.1 carpet/turf setups out there though.
I would assume I could use one of them if somebody can recommend a b.b. shock setup for high grip carpet.
Or if there is a 4.2 carpet setup out there...can somebody point me to it.
Car coming this week...trying to absorb this thread as fast a possible.
Thanks.
j.d.roost is offline
Old 05-13-2013 | 12:51 PM
  #5124
Matt Trimmings's Avatar
I believe the avid is 7 grams lighter than the v2...when the triad came out hardly anyone was using a vts in a 2wd application (it was primarily a 2/4wd sc thing).
Matt Trimmings is offline
Old 05-13-2013 | 01:16 PM
  #5125
Yeah I thought the avid was the lightest option
Old 05-13-2013 | 01:30 PM
  #5126
It might be. I am only going off memory here. If that is the case then it would be a lot lighter then the VTS. Somebody mind weighing one for us?
chevmaro is offline
Old 05-13-2013 | 01:38 PM
  #5127
Copied from the avid site
light weight, compact design (TRIAD 11.2g Vs. Stock 16.4g)
That could be V2 and VTS is 7g.
chevmaro is offline
Old 05-13-2013 | 01:45 PM
  #5128
the incubus's Avatar
Thanks.
All I know about Carpet setup is that some people prefer the gear diff over the ball diff. How or why is beyond me, as I feel I can fine tune my ball diff to perfection for any environment and level of grip. The 4.2 I traded for had the gear diff in it and it was almost un-drivable (for me) but I swapped it out for the Ball diff and suddenly it's a whole new car and just as easy to drive as my T4.1.
the incubus is offline
Old 05-13-2013 | 01:57 PM
  #5129
V2: gear, pads, plates, spring and spring washer =17g
VTS: same as above =23g
Old 05-13-2013 | 02:06 PM
  #5130
Cain's Avatar
Tech Legend
Thanks.
the stock B4.2 setup actually worked really well. One of the big things that helped for me was using the lightest rear sway bar available.
I also went up I believe 2 spring sizes up front and 1 in the rear over stock.
I'll take a look and see what i ended up with. Mind you I didn't have carpet specific tires like Dboots of yellow mini pins so you may fine you need to stiffen things up a bit more.
Cain is offline
