Team Associated B4.2 Thread >
Like Tree4Likes
Old 03-18-2013 | 04:44 PM
  #3031
Venom1836's Avatar
Question:
How much harder is a Gold JC Tire Compared to a Green JC Tire?
Or are they both for completely different surfaces?
Everyone who runs Gold says they last forever, and Green guys say they dont last long
Venom1836 is offline
Old 03-18-2013 | 04:56 PM
  #3032
Wildcat1971's Avatar
Anyway, a visual is always nice. Here are 3 pics of the same tire. worn out or not?
to me it looks like the 3rd rib from the left has lost 1 of its edges.
http://imageshack.us/a/img20/9297/tire2c.jpg
http://imageshack.us/a/img5/1162/tire3e.jpg
http://imageshack.us/a/img832/1256/tirej.jpg
Wildcat1971 is offline
Old 03-18-2013 | 05:13 PM
  #3033
Originally Posted by Eli
Never thought i liked tapered pistons before in the v2 shocks but in these big bores the AE machined tapered pistons work awesome!
On my medium bite large indoor track with about a 70% clay content i am running the green/white ae springs 32/30 ae oil 3 hole 1.4 pistons up front and the 2x1.6 in the rear. The rest of my car is pretty much identical to Steven Hartsons setup as far as i know except servo, i am running the airtronics94930 servo with my m12
I came to this conclusion of piston set-up after running first the 1.4x3hole front and rear then noting how my car felt then running the 2x1.6 front and rear and noting how it felt.
Seemed the 3 hole didnt give me enough pack for our large jumps but then the 2 hole 1.6's felt too stiff and not quite balanced in the front so i put the 3 hole pistons in the front and my car came to life, not that it was bad before but i felt more connected and had better steering since my front end dove into the corners more consistent. On a higher bite track it may not be ideal, but time will tell on that one.
Also ran green pressure points in the back with gold barcodes front a few days after running the above set-up and i was amazed how well they work and with the white sticky kicks im not getting excessive wear either. The track wasn't dry either and i usually wouldnt run a green compound unless the track was dry but i was just as fast if not faster with the green pressure points then my v1 gold barcodes. If the track was dry they may have got eaten up fast but thats the trade off.
The pressure points are very smooth and consistent, broke in pretty quickly as well. I ran a medium insert. The carcass fits tight around the foam compared to some super soft tires which most likely helps keep them feeling smooth and not edgy around the track.
Im guessing these feel similar to the Ions that everyone is raving about but not certain since i havent tried a pair.
Were the 1.6's the new machined ones from AE? Did you try the 1.3 x4 for the pack and slow speed dampening. Did you try the 1.6s up from with 30/30 oil? That would have taken away some of the pack.
Old 03-18-2013 | 05:34 PM
  #3034
???E-Racer's Avatar
I plan on running ribbed tires on the front.
I can understand they not hooking up on the indoor tracks. But I'll be outdoor.
Indoors I think front suburbs would be better, but I hear the scrubs are good too.
???E-Racer is offline
Old 03-18-2013 | 05:52 PM
  #3035
ae-Dan's Avatar
What do i need to put the vts clutch on my car? I have the v2 on it now.
ae-Dan is offline
Old 03-18-2013 | 06:14 PM
  #3036
Blitzrockey's Avatar
Are most people using the stock plastic servo horn or going to aluminum? If so whats the best aluminum one to go with for a futaba horn? Thanks.
Blitzrockey is offline
Old 03-18-2013 | 06:15 PM
  #3037
JasonC's Avatar
Back in the day with ribbed tires once the ribs went from "sharp" to rounded it was time to replace them. But then again it always comes down to driver descreation
JasonC is offline
Old 03-18-2013 | 06:37 PM
  #3038
a vts and maybe the clear gear cover. check the part number on the gear cover for the b4.2. But i thought the clear cover was needed.
Old 03-18-2013 | 06:38 PM
  #3039
I use the plastic one. And have yet to break it. And i crash a lot.
Old 03-18-2013 | 06:39 PM
  #3040
huzzler's Avatar
Hitec and Losi make good aluminum servo horns.
huzzler is offline
Old 03-18-2013 | 06:40 PM
  #3041
Eli's Avatar
Eli
Originally Posted by Venom1836
Question:
Gold is a lot harder and has a different feel at my track. My track is fairly unique with its mixtures of top soil and various types of clay. Some people at my track only run super soft type tires. Depending on how long the track has been in for depicts which tire i will choose. When the track is fairly new and hasn't developed a really hard and smooth surface i will run a gold tire (v1 barcode) that is freshly broken in so it can dig in and also not clog up as easily. The track is usually very very moist during this stage of the life of the layout. In about 2 weeks after the layout has been in a nice blue/black groove can be noticed in the groove, at this time i can run either a green tire for insane traction or a gold tire for about the same amount of grip but a tad free'd up in the corners. I will usually stick with a gold tire because i can usually run faster lap times with it. In this case i wanted to try these green pressure points and my track is at that 2 week mark so i decided to give them a whirl and it went really well. I was able to run the same fast lap as i was with gold barcodes. I believe the reason for this is due to the low and consistent tread design. As far as life expectancy depends on how dry my track is, the more dry the greater the tire wear. On average i will guess i can get a gold tire to last probably 5-10 times longer (i know thats a huge window). I will take a guess that i will get about 7-8 race days out of these green barcodes judging on how much wear they have with 3 full packs on them maybe even longer. Lately the track conditions and prep has been the best it has ever been since OCRC has let us use their track building equipment. (Thank you Robert Black). We had an out of towner come race last wednesday and he ran panther slicks in our 2nd qualifier i heard and i think he ran a real good time with them but im pretty sure he did not run them in the main. The groove at sdrc is pretty wide since we have a lot of 4x4sc's and 8th scales run on the track and they use a lot of the track to get around
So to answer your question, green imo would typically be ran on a track that doesn't have a very very high clay content and/or if it is ran on the dry side, the blue compound (soft) could also maybe be a option in these conditions.
In my case with our clay content both compounds work well and the super softs are usually easier to get to work if your set-up isn't as perfect.
Golds will last a very long time unless you are using a real potent sauce during a dry-moist track condition.
Ya its lost some edge, not sure if i would say its worn out unless your car really pushes bad but i would run it if it were a club race.
yes the 1.6's were machined. Didn't have the 1.3x4 pistons. the only machined pistons i have are the ae 2x1.6 tapered, the ae 3x1.4 tapered and the avid 1.5x1.1 two plus two flat pistons. I tried the 1.4x3 pistons with 30 up front and it was too soft and with my findings with the 1.4x3's i skipped trying the 30 oil up front. I heard after my findings that with the tapered pistons 32/30 front and rear should be about right. I thought about trying 30/30 with the 1.6's but wanted to try the 3 hole with 32 since i had a feel for it already and i had a good feeling about them and i made the switch during my 2nd heat during one of my last club races.
Eli is offline
Old 03-18-2013 | 06:42 PM
  #3042
Keep in mind the losi is threaded for 3mm and the b4 used 4-40.
Old 03-18-2013 | 06:51 PM
  #3043
I assume the machined 1.6's felt much better than the stock 1.6s? I also think for my track the tapered piston would be very good. The track is not super smooth and with the weather, it can get a little lumpy. not a big deal at lower speeds, but it can be hard to keep up high speeds and keep the rear planted.
Old 03-18-2013 | 07:00 PM
  #3044
man they aren't even broken in yet
Bob Barry is offline
Old 03-18-2013 | 07:05 PM
  #3045
lol, those ribs have gone through 2 sets of rear so far, lol. but yeah I think they were gone per say. I have been chasing steering, so thought that might be the cause.
