Tekno SCT410 Thread
a tekno 1/10 4wd buggy and a 2wd SC would be awesome! I sold my durango 4wd buggy
because it has sat up for a year with only 3 race days on it! It was a beast and had all of the toys on it! Please TEKNO, when u make a 4wd buggy, make it as awesome as the other kits! Just sprinkle some shrinking dust on the eb48.2 and make it 1/10 scale size, and BAM, ANOTHER top in class Platform then the 2sc and same thing...
2wd sc for me first...time to dominate something in 2wd
For topsoil mixture and even some clay tracks I've found that HB Beams, HB Megabites and AKA Wishbones are pretty good starting points and decent tires to have in the arsenal.
If your not against a dish wheel, that's what I'd recommend.
And to all... I conceded to defeat on the 17mm hex until my buddy finishes machining a set for me. Then the 17's go back on The plastic spacer for the Tekno hex's lasted me about a pack before they quit so their out for now.
Tires are more of a question you want to ask locals at your track, as far as rims I have used DE Trinidads, DE Borregos(don't like dish for sc but that's all they had), next set is avid sabertooths...none of these needed dremeling or anything and all in scte offset
On the wheels, Losi scte rims seem to be the most widely used but I just picked up the DE Borrego 12mm rims and the inner webbing cleared fine and the 17mm version used on my Mugen sct has months on them and their still close to true... certainly no cracks or anything like that. They are more true than any other rims I've run for the given time period.
How did you like the AVID wheels?
I just picked up an SCT410 so I'm excited to be a member of the club. I have never raced before but it looks very tempting, but I'll probably just get acquainted with my Tekno a little before I jump in.
Quick question on motor choice. Reading up as much as I can on the Pro4 HD 4300, but can anyone with that combo chime in. I have a Pro4 4600 I just pulled out of an exo but tempted to switch it up.
Thanks!
Thanks!
Thanks!
Thanks!
What gearing for the Hobbywing 4000kv motor.
Anyone having problems with the carbon rear shock tower ? I just put the Tekno tower on my truck and after the first run noticed a small crack in it by the diff case . I didn't take a bad crash in the heat race I was in , so I'm not sure what would have caused this . Could it be just a flaw in the tower ?
I'd recommend sticking with stock and replace when it gets a little bent.
Start around 17-18t.
I really like mine. All i run on this truck. A little flexy, but nothing that isn't comparable to other wheels on the market.
What shock pistons are stock? 8x1.3?
