Tekno SCT410 Thread >
Tekno SCT410 Thread
Like Tree17Likes
Tekno SCT410 Thread
Old 07-23-2013 | 06:10 AM
  #12436
Looks like Tekno added a straight cut diff pinion. Pros? Cons?
http://www.teknorc.com/shop/tkr5152-...t-cut-10t-cnc/
and ring gear
http://www.teknorc.com/shop/tkr5151-...t-cut-cnc-40t/
Mullet1 is offline
Old 07-23-2013 | 06:28 AM
  #12437
vfrninja's Avatar
Hmm. No description, I wonder what this is for. More efficient maybe.
vfrninja is offline
Old 07-23-2013 | 06:30 AM
  #12438
maybe cut down on noise? let's hope.
Mullet1 is offline
Old 07-23-2013 | 06:33 AM
  #12439
Bcholka's Avatar
TKR-6008 (updated shock guides) are in stock at Tekno!
Let's get the DLC shock shafts out next!!!
Bcholka is offline
Old 07-23-2013 | 07:56 AM
  #12440
suby723's Avatar
Coming from my auto racing background straight cut gears are even louder. Take reverse for example in a manual transmission. Reverse is always straight cut.
suby723 is offline
Old 07-23-2013 | 07:59 AM
  #12441
nmdesertracer's Avatar
helical cut gears are quieter. plus they can take more load vs straight cut.
nmdesertracer is offline
Old 07-23-2013 | 09:02 AM
  #12442
bronc4now's Avatar
^ Yep thats why I was surprised to see straight gears..
O and im new to this tread because I just picked up my sct410
Now I have reading to do ...later
bronc4now is offline
Old 07-23-2013 | 09:07 AM
  #12443
snwchris's Avatar
Bronc4now... the first page has alot of great info and will help anwser some of the most common questions. Feel free to post up if you need help. It's a great thread with alot of helpful people and information.
snwchris is offline
Old 07-23-2013 | 09:11 AM
  #12444
jhautz's Avatar
The gears that come in the kit are straight cut also. Tooth count looks to be the same. Not sure whats really different except the pinion appears to be ground on the bearing surfaces. Maybe jut a higher quality gear set??? Not sure why though because the stock gears have been just fine.
I wouldn't mind seeing an optional set of gears to allow over-drive on the front diff or under-drive on the rear diff. I always loved that option on my xray and mugen cars. Really made the car drive great on low grip tracks.
jhautz is offline
Old 07-23-2013 | 09:23 AM
  #12445
EbbTide's Avatar
Yeah like jhautz said, the stock gears are straight cut as well. Looks like the new pinion gear is coated in something; maybe anodized? Or something similar to DLC coating.
EbbTide is offline
Old 07-23-2013 | 09:32 AM
  #12446
Now that you said that it reminded me of straight cut in cars. Well I ordered 2 sets and will see what's what
Mullet1 is offline
Old 07-23-2013 | 09:38 AM
  #12447
cpt_RedBeard's Avatar
it's been a few days since I've had my diffs out, but aren't the stock gears already straight cut?
**EDIT** I'm late to the party I see....
It looks like 5111 are cnc machined is the main difference. The only difference I can see in the pics are the machining around where the bearing goes.
cpt_RedBeard is offline
Old 07-23-2013 | 09:58 AM
  #12448
kman16jr's Avatar
The all black pinion what everyone has is straight cut but has a very slight curve in the gear vs. the new one being completely straight as it is supposed to go with the ring gear.
kman16jr is offline
Old 07-23-2013 | 10:06 AM
  #12449
colormegone's Avatar
I got my 410 used and it has no rear or center brace? I know they come with them and was wondering if I should order some. Any thoughts...... I run on a large 1/8th scale track with big jumps and hard landings. I would think that if Tekno designed em that way then they should be on it....
colormegone is offline
Old 07-23-2013 | 10:13 AM
  #12450
i would probably run the back brace for large jumps.
