Tekno SCT410 Thread
Question for you all. I have a PRO4 HD motor and am getting some pretty high temps on short runs. Adjusting the pinion down to a 15 puts it in the range around 150 (which is fine) but the owner was asking me about the timing I am using and.....well....I don't know much about that. He suggested it may help with temps and also improve run times (currently about 12-15 min on a 6000mah lipo) Im not racing hardcore just running on an outdoor med-loose dirt track.
I am using a Castle MMP ESC (RX8 going in for service).
I know runtime with a HD motor and a heavy truck is never going to be GREAT.
Question is, what timing should I be using for the PRO4 HD 4300?
Question for anyone using the savox 1258tg. Can you show a pic of how the horn is attaching to the servo? Mine is not looking right and I am not sure how I can get it level to work correctly
So anyone here having any wobble issues with the aluminum front drive shaft? My steel one is about done I think it has a lot of wobble and I added o rings to quiet it down.
Does the aluminum also bend like the stock steel one? If it lasts longer than the stocker even that is fine.
Grid any news on the titanium one for a sct as well? I know they are making one for the buggy drive train.
Tekno RC takes 1st & 2nd @ RC Pro Ontario Rd2 - The Barn Yard
This past weekend was round 2 of the RCPro Ontario provincial series in Canada. The 100+ entry event was hosted by The Barn Yard in Stratford Ontario, 75 minutes west of Toronto. The track owner did a great job preparing for it's third RCPro event. The track offered a high speed back straight, good mix of table tops, step downs, ski jump, camel back and challenging woop section.
Under sunny warm sky's Rob Patch was able to put his Tekno RC SCT410 to TQ honors over me (Shawn Fraser) sitting in second. Rob was able to keep out front and stay out of trouble to finish the first two triple A main's in 1st. I took 1st in A3 and finished 2nd overall.
Any word on aluminum hubs?
-Thomas
Sorry to ask this but why are people saying to get the aluminum hexes on all four corners and ditch the old plastic ones. What's wrong with the plastic ones?
The plastic are fine but they are prone to stripping out over time or if the wheel nuts some how back loose a little. It is just better to know that your hex's won't strip put in a race or practice(when this happens it usually strips the hex out on the wheel). TKR1654X will make the car 1mm wider on each side making the truck as wide a possible but still within the roar legal width. But TKR5171A is stock width.
-Thomas
TEKNO RC
Customer Service
(858) 997-0833 Ex:2053
Some people reported that they strip. I own both and haven't needed to install the aluminum ones yet, and I've owned the truck since it release.
Trader Rating: 53 (100%+)
Hey Tekno brothers. Raced my truck for the first time this weekend. Now, my 4600 Pro4 motor was a screamer in my FT SC10 4x4 last year. Felt lazy in my Tekno, even before pinion and esc changes. Had to turn punch down a lot to keep temps in check which made it even less exciting. Thinking that I may need a ballsier motor. Thinking either the 4700 Hobbywing or 4300 Pro4 HD. If you had a 4600 Pro4 and switched to either of these, what are your thoughts and did either motor run cooler? The truck felt good otherwise but needs a little adjusting. Thanks fellas. As always, great info and great guys offering help on this thread.
Thanks Mullet! That's my initial thought. What pinion are you running? Does that motor run cooler than the 4600 Pro4? I'd think so since it doesn't have to work so hard to move this big girl, but I've seen other posters say that the 4300 HD runs hot. I run a Viper VTX8 esc and SMC 7200 batteries so I'm not concerned about my electronics being up to snuff. Thanks again man!
