Tekno SCT410 Thread
ok, cool. I might try the small packs in the heats and use the 7200ish for the mains, thx
TQ and the win at monsters of the midwest series rd 3 in louisville this weekend with my dialed sct410. track got super blown out to where you couldnt jump a couple jumps and had to roll them for consistency. took 2nd in nitro truggy. 2nd time ever running nitro with over 25 ppl in that class. cant wait for the nt48 to come out. 6th in ebuggy, a very rough start with 15+ cars on a 20 second lap track. not a good idea, but the eb48 is feeling great with the fioronis!!!!
Smc has some out of spec race formula 7200's that are $20 or so less, 200-300 mah less with even lower IR. I'm thinking about grabbing one while he still has them even though I don't need one. (Already run 7200 race packs)
I've read about other people having this noise issue. I must've done something wrong cuz mine is almost silent. My friend Jason Snyder said the same thing about his. Maybe my kit was defective? Should I contact Tekno about this, and see if they can send me the loud parts?
Last edited by Cptn Cartwheel; 06-18-2013 at 04:28 PM. Reason: im a grammar nazi, I even correct myself
i found,by accident, that a lot of the noise comes from the spur gear/pinion. i was switching pinions and put a durango part in and there was a significant drop in noise. when i went back to the tekno pinion the noise came back, cant explain it because i checked the mesh and all was good. the pinions line up as well...
Loud Trucks save lives.. Corner marshals can hear you coming. My truck is kinda loud but on the track I really dont even notice the noise.
5200kv cranking up to full rpm in the air for flight correction is loud.
Normally, not so much.
I haven't driven it yet, but I think the new kit I got and am building is going to be louder. The mesh to the rear diff from the pinion is much more loose, even shimmed as tight as I can make it. We'll see though, hoping to have it out tomorrow for some fun.
R/C Tech Elite Member
Noticing some pretty high gearing on these, I have a 13t pinion on my car (using Pro 4 4600) and I still need to set the EPA to 70% on throttle, far too much on our track! Some of the set ups are using an 18t pinion on a similar motor. In a 5 minute race I am using around 2700mah (RX8 esc)
Mine is also very quite. Even when I was first testing the truck with the brand new spur, it was still quite. It might be because I use Novak pinions.
I've bent my rear shock tower. Should it lay flat on a piece of glass?
It looks like it's got a little factory bend in it.
