Tekno SCT410 Thread >
Tekno SCT410 Thread
Like Tree17Likes
Tekno SCT410 Thread
Old 05-21-2013 | 02:20 PM
  #10321
Bcholka's Avatar
Originally Posted by ryanpatrickgore
a couple guys at my track are using 20-30K in the center diff to get more pull and power steering
Now that's interesting!! Well at least that makes me feel a little better experimenting with a higher center. Do you know by chance what they're running in the front and rear with the 20-30k middle setup? What type of track? Indoor/outdoor/type of bite?
Thanks!
Bcholka is offline
Old 05-21-2013 | 02:22 PM
  #10322
Originally Posted by Bcholka
This is where I get confused-because in the hudy book it states that going thicker in both front and center will increase on power steering. I know if you go
too high in the front you will lose too much off power steering. I'm at 10-10-2 and liking it right now. Thinking of going 10-15-2 for med bite indoor track. Thoughts??
Things like the Hudy setup guide are rules of thumb. I take it all with a grain of salt. With every chassis I have set up I use the knowledge gained from previous setup to get me started. However, I keep in mind that because it worked on a previous chassis it does not mean it is going to work on the current. In a lot of cases, a setup change will do the total opposite that is written in a book or stated on a forum.
Ben Burtle is offline
Old 05-21-2013 | 02:31 PM
  #10323
ryanpatrickgore's Avatar
Thanks!
I want to say 10/30/5 but I just can't remember or be for certain. Next time I see then I will ask. Umpy visits this forum and he is running this type of setup. Maybe he will chime in
ryanpatrickgore is offline
Old 05-21-2013 | 06:32 PM
  #10324
For tight indoor (TRCR) I'm running stock front (7k), Center (30k) & rear (3k).
Seems to work for me. I think Brian (Umpy) is running something similar to this too. Truck still has gobs of steering --both off power & on power. I think the heavier center helps forward bite which is needed on a tight technical track like TRCR where you are darting from one 180 degree corner to the next 90 degree.
my 2 cents.
JASF4I is offline
Old 05-21-2013 | 06:45 PM
  #10325
sickpuppy1's Avatar
I'm running 10 10 2 on loose dirt and love it.
sickpuppy1 is offline
Old 05-21-2013 | 07:00 PM
  #10326
JRapid's Avatar
Look what I got!
JRapid is offline
Old 05-21-2013 | 07:06 PM
  #10327
DriveItLikeYSIT's Avatar
Originally Posted by JRapid
Look what I got!
Welcome to the darkside..Your gonna kick yourself for for holding onto to the RCE & not getting the sct410 sooner !!!
DriveItLikeYSIT is offline
Old 05-21-2013 | 07:16 PM
  #10328
SOuthernFRIED's Avatar
I just gotta say y'all are making me want one of these bad...
And
Go Noles!!!
SOuthernFRIED is offline
Old 05-21-2013 | 07:38 PM
  #10329
Wildcat1971's Avatar
1) any idea when there will be more kits available on the tekno site?
2) has anyone tried 2x shorties in parallel?
Wildcat1971 is offline
Old 05-21-2013 | 09:46 PM
  #10330
I'm runnin 7/30/5 and really like it I'm also runnin lower inner hole on rear tower and the inside holes on the rear outer hinge pin turns on a dime very consistent and predictable
umpy907 is offline
Old 05-21-2013 | 09:49 PM
  #10331
suby723's Avatar
here is my setup sheet that works great from indoors to outdoors, low bite to highbite.
suby723 is offline
Old 05-22-2013 | 02:36 AM
  #10332
Bcholka's Avatar
Thanks much guys (about the last 5 or 6 posts) for your info on your setups. I'm going to try going from 10-10-2 (which is decent) to 10-30-2. I like what JASF4I is saying about the "darting" from turn to turn--that's exactly what I need at our track. Also thanks suby723 for posting your setup-I'm going to try your recommendation on lengthening the rear camber link between the tower and hub.
Ill also be trying my vented shock setup with foam compensators which Ill report back on.
Lastly-I emailed Tekno to find out the ETA on the DLC coated shock shafts--gotta keep that stiction to a minimum!
Ill report back soon!
Bcholka is offline
Old 05-22-2013 | 05:16 AM
  #10333
Originally Posted by Madjake
How often are you guys changing diff fluid and rebuild
I change diff oil after 4 race days. Keep it fresh.
maizer is offline
Old 05-22-2013 | 05:47 AM
  #10334
ShrinerTony's Avatar
This is very close to the setup I'm running in my truck. The only differences i really see is the camber lengths being longer. I'm still using the stock locations. What are the biggest differences in changing them to the longer camber length? I love my current setup and how it just works for both indoor & outdoor.
ShrinerTony is offline
Old 05-22-2013 | 06:41 AM
  #10335
Bcholka's Avatar
Always a good idea, however, these diffs hold much more than certain "other" SC's out there so you will not have as early of a breakdown of the fluids. The capacity of these is right up with there with my Mugen Eco--true 1/8 scale diffs (and pretty much the rest of the truck for that matter!!!).
Bcholka is offline
