Tekno SCT410 Thread
I was up to 40 fr 35 rr and even moved the rr shocks out to outside hole on tower to make it stiffer this weekend. Coulda went stiffer in front by 1/2 wt. felt good. It was high bite tho at Crcrc Midwest champs. Finished 5th overall in pro4 and 4th in b main in Ebuggy against some fast dudes.
ok i was just going to try adding weight, how much did you add? i was wondering if it would work because everyone was was saying chassis slap in rear was causing the nose dive and weight should increase the slap off of the jump face, good to know it worked.
what springs, oil and pistons are you running front and rear?
I think it has to do with springs, what rates are you running? Guessing at the higher range of rates like sramos if your 40/35. I'm on the low end, greens.
To level it and I love it
I'm telling you guys the 8x1.3 pistons flipped with emulsion build is where it's at I have a set of fioroni pistons sitting in my pit bag cause I found this to be better
My setup http://www.petitrc.com/setup/tekno/S...knoSCT410.html
Under josh havens
Under josh havens
Im very tempted to try these. http://www.amainhobbies.com/product_...Set-Kyosho-MP9
I don't think that's really true all over. It really depends on the track you're on. Tighter tracks will demand more braking, otherwise you're just going too slow. These 4x4 trucks already have much more neutral drag than the 2wd's, so that helps not needing to use brakes as much. That coupled with the fact that we can rotate the truck using throttle helps a lot to.
At OCRC, being a hard pack high bite clay indoor with misters, the Tekno SCT410 does a lot better when you enter into the turn a little slow, then power through the turn. Often doing drifts around them. At least this is how the fastest guys run it (both Tekno trucks). I'm slowly learning, it's not as easy to learn power driving around a tack than it is to learn to be smooth. Power driving when learning yields more crashes. The body is sure taking a beating as I learn, but I have yet to snap anything, knock on wood, yet...
I'm going to be moving to the Fioroni Pistions as well and will be trying out SRAMOS' setup, with the exception of one stop softer springs all around and using AE oils close to the Losi oils he is using this chart: https://www.google.com/url?sa=t&rct=...59026428,d.cGU
However I'd love to hear from other people running the Fioroni pistons!!!!!
It would have less pack with a faster compression and slower rebound.
Well all of the frustration and tuning finally paid off!
truck is dialed no more nose dive. I changed my driving style and the key ingredient was adding weight to the rear of the truck. I will post setup when I get a chance. Hard packed out door blue grooved track. Finally can say the tekno truck is my favorite. Thanks for making an awesome product Tekno! Keep up the good work!
yeah, i was getting down on some oils so i ordered some up. ordered down to 20 just in case.
i don't get a lot of test/tune time. track is too far away. for me, i only get maybe a pack on race day before racing starts. i need to be close when i get there (what "feels" right on bench) and then maybe one or two tweaks before racing starts. i will still give sramos' setup a shot before changing (even though the oil feels too heavy). maybe with the pack these have, i can get away with a lighter spring in the rear if i go down on the oil. i'm just paranoid of the dreaded nose dive if i go too soft on the rear spring.
Don't remember ever discussing "bench testing" on here but I have been curious of the different techniques and opinions.
17Likes
