Xray XB4 thread
Has anyone noticed their chassis is bent like a banana ?
After only a few race meets mine is , no big crashes etc , same deal with my 17 ?
Its not to do with the flex screws because the bend starts where the spurs is .
I've ran mine straight into a brick wall and a steel pole and never bent a chassis.
Been running my 16 for 2yrs and chassis is perfectly fine, that's with some hard crashes on dirt and carpet
On the 18 is the pill setup from the manual wrong like the xb2
my son is very tough on his and never bent
What the best setup to keep the rear of the buggy from losing traction on power?
Hi,
Needs your help here, as I never ran spec before.
Can you recommend for best 13.5T motor and with which gear?
Will use it with the Orion HMX blinky.
The track is Norcal Hobbies, small indoor clay track.
Setup help will also be appreciated...
Has anyone heard of a new 19
edited...moved to appropriate thread
Hex
I have the 2018 xb4. I'm trying to figure out the chart at the start of this topic about hexes I would like to reuse my wheels from tlr 22-4 since I have a bunch. What hexes do I need front / rear ?
mark
mark
Ive used the stock front hexes and 6.5 mm rear hexes with those wheels and it seems pretty close to stock width
R/C Tech Elite Member
Yea but typically the actual car is not available until November/December or January time frame based on past releases.
