Xray XB4 thread
servo horn
I would like to know why xray/hudy can make a plastic servo horn that dont rub the body but they cant copy it in metal
I ran 26/78 with a Fantom V2T team works plus.
Here’s the 23T version #293497:
https://www.hudy.net/xhudy/products/proddesc.php?prod_id=776&kategoria=67
Here’s the 24T version #293498:
https://www.hudy.net/xhudy/products/proddesc.php?prod_id=777&kategoria=67
And here’s the 25T version #293499:
https://www.hudy.net/xhudy/products/proddesc.php?prod_id=778&kategoria=67
Bent
What are most people running for springs, progressive or linear? I see that the 2018 has linear now and the 2017 had progressive.
I just picked up at 2017 and will be running on turf
The shorter springs that was included in the ‘17 kit we never use.
They did not come out as intended and is no longer included in the new ‘18 kits.
Bent
BentKa..... what's your thoughts on the Ring & Pinion issues that some have been posting up. I run Mod class with 6.5 and trying to decide if I should buy....
Cast Steel ones again...
Composite Ring & Pinion
Composite Pinion & AL Ring Gear....
at the reedy race this past weekend.. the team all ran the composite ring and pinion.. they did take them out to check wear.. but.. they used only one set all weekend..
OK, good to know and hear
