Like Tree248Likes
Xray XB4 thread
Old 02-28-2016, 01:47 PM
  #10576
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by grifind
Last night i rebuilt my shocks on my xb4 and one of my rear shocks no matter what or how many times i tried, it doesnt work properly,even on 0 or 100% rebound. it juststands still wherever i press it. any ideas what it might be? damaged o-ring, central pin? or..?
First thing I would check is if the shaft is bent. Doesn't take much of a bend to bind up the shaft. Like advpball said roll it on a piece of glass.
rcgod is offline
Old 02-28-2016, 05:27 PM
  #10577
3srcracing's Avatar
Trader Rating: 29 (100%+)
Does anyone have a good setup for high grip carpet with 1.6/1.7 stock pistons? Or what setup should I try with stock springs/sway bars?
3srcracing is offline
Old 02-28-2016, 05:45 PM
  #10578
http://site.petitrc.com/setup/xray/S...tsXrayXB4.html
You can find plenty of setups here for any surface and grip conditions you need
grifind is offline
Old 02-28-2016, 09:56 PM
  #10579
gticlay's Avatar
Trader Rating: 14 (100%+)
i did but it seem fine :/
I would suggest that you replace the shock shafts on both of the shocks on that end, and new o-rings/guides. Keep the "good side" for a spare. You'll know after replacing those parts.
gticlay is offline
Old 02-29-2016, 04:27 AM
  #10580
TPR 1's Avatar
Trader Rating: 26 (100%+)
My 15 running saddles is still quicker on my local outdoor track , than my 16 with shorty configuration.Its a low traction track so I've bought the medium side guards,chassis braces etc rest of the set up is identical.
-fastest time with 15 single lap 22.048 and race 14 laps in 5min 20.478 sec
-fastest time with 16 single lap 22.635 and race 13 laps in 5 min 5.106 sec
Track conditions have been identical and use brand new tyres every second run.
Im comparing these times with running 4 race meets with the 16 and doing
10 race meets with the 15
anyone else slower with their 16 compared to their 15 in low traction ?
The only thing i can put it down to is running saddles on low traction is faster for
me.
TPR 1 is offline
Old 02-29-2016, 06:21 AM
  #10581
onekiwi's Avatar
me.
Maybe try the 16 with the motor moved back (to the 15 position)
On lower traction that has helped.
onekiwi is offline
Old 02-29-2016, 07:56 AM
  #10582
me.
Is that just outdoor or indoor too, Because I think my 16 is alittle faster indoors being its a shorter chassis now and can turn better/faster. as its winter here and we are not running outdoors yet i have yet to run my 16soec outdoors.
randy0025 is offline
Old 02-29-2016, 08:44 AM
  #10583
TPR 1's Avatar
Cheers onekiwi i forgot about that
TPR 1 is offline
Old 02-29-2016, 08:47 AM
  #10584
TPR 1's Avatar
Just outdoors.
TPR 1 is offline
Old 02-29-2016, 11:52 AM
  #10585
i just ordered a pair and this is what i will try to do first thank you
grifind is offline
Old 02-29-2016, 04:09 PM
  #10586
Trader Rating: 43 (100%+)
me.
I have the brass rear hangers on my 16 which are a huge plus on low traction. I also feel the ECS front and rear swings shafts promote better traction on low bite as well. They rotate much cleaner and tighter thus smoother, which I believe translates to decreased twitch and vibration.
I guess the best analogue I can make regarding the ECS front and rears helping on low traction as well would be the following. Lots of people balance their wheels for better performance. The ECS fronts and rears are basically a much more balanced while rotating more freely through out the constant travel within the suspension. Their rotation under and off power is very precise, thus not sloppy, not wobbly, but nice and tight, while rotating with less friction, vibration etc.. Smoother delivery of power to the wheels.
Norse is offline
Old 02-29-2016, 04:11 PM
  #10587
Anyone have recommendations for narrower pinion gear brands, thus grub screw being closer to the teeth. It's been a little bit if a pain trying to obtain a full pinion to spur mesh as with motor mount preventing blocking access to the grub screw. Was thinking about dremeling a channel on the motor mount itself but I would rather not if there is a brand of pinion gears that work better.
Norse is offline
Old 02-29-2016, 05:38 PM
  #10588
That's what I did. I think this was an oversight. However, any 21 tooth or lower pinion will fit thru the cam hole so if you don't want to take a dremel to the motor cam, just install the pinion before installing the motor cam.
Tony Vega is offline
Old 02-29-2016, 05:58 PM
  #10589
Perfa! Man I am a moron at times many times at that (lol) as I had a 22 on and did not even think about smaller pinions fitting thru the cam. Well I did think much smaller pinions would go through, however I didn't even think to try a 20 or 21 as I just assumed the opposite.
Thank you as I really did not want to drop $16 for XRAY pinions. Their nice however a tad to expensive plus I just picked up a bunch of new SWorks pinions.
Norse is offline
Old 02-29-2016, 07:09 PM
  #10590
TPR 1's Avatar
Does anyone know if the 81mm cvd fits ok combined with the 95mm cvd for the centre drive line?
TPR 1 is offline
