Xray XB4 thread
#9676
On Ozite carpet with clay compound slicks, I went from that feeling with 10K front and 10K rear to 20K front and 10K rear and it was soooooo much better coming into corners full brake, kept a ton of steering for the 180's, and good traction out. Edit to add: I also went up 15wt in the front oil and 5wt in the rear.
#9677
yes i have read page in the book like 10 tens and i still dont understand it.
I guess where I get lost is if for example, if you get the inserts that have the dots in the middle but toward the inside it say -1.5 track, well what would the Anti Squat and Roll Center and Toe In? sorry if this is a really dumb question i am normally good at this stuff but just dont get there system. thank
Bent
#9678
Has anyone used a '15 or '16 body on a '14? I know the newer bodies are slightly wider but if I used Velcro on the sides would that close up the fap good enough?
#9680
Yes this is intentional.
This lets the suspension work much better at lower ride heights like 15-16mm and adds overall grip to the car.
What you refer to as twitchy we refer to as added steering
Standing the shocks up will make it more twitchy.
To calm it down we lay the shocks down, not stand them up
What surface are you running on and with what tires ?
Bent
Bent
What kind of traction levels are you racing on? Going up in your diff fluids will calm down the "twitchyness" or what I like to call responsiveness. With the lighter diff fluids the car will rotate faster off the center point of the car.
Tell us what exactly the car is or isn't doing and let's see if we can dial it in for you a bit.
The surface is medium to high bite clay. Surface is similar to like. CRCRC or SDRC but less grooved on the outside of the lines. The current tires for the track are gold dirt webs, soft electrons, chain links and Panther bobcats and rattlers. I'm running rattlers rear and bobcats up front.
What the car is doing:
The car seems really wild exiting corners. It seems edgy, like I have to really stay vigilant of its direction and make constant inputs to keep it online. It is very responsive in the air but landing seems less plush or firm as my 15 does. When it lands, the cars seems to ignore my commands a bit and sort of keeps moving when I'm on the brake to get into a corner, almost like it's sagging on braking. The slipper seems good to me. I just want the car to be easy to drive. I can't race an edgy car, I like clean consistent laps.
If I'm at 7k front and rear dif oil, and went up to 10k front and 8k rear would this be a good starting point? Considering laying down the shocks but I was always told laying them down adds steering and standing them up removes it. I'm wondering if I've got this backwards. They are presently in the middle position. Any suggestions would be helpful.
#9681
Surface and tire:
#9682
Hi Xray guys!
I want to use my Associated B5 rear wheels on my XB4 16. Does anyone know which 12mm Hex will fit to respect max authorized track widths?
Thanks...
Thanks...
#9684
XB4 ackerman steering rack
Will have an XB4 before Christmas... pretty stoked to get it.
All this talk about the 2016 being twitchy has made me a little nervous : ) On my previous wheeler I used the outer front ackerman adjustments to tame down the initial steering. I understand the stock factory ackerman bar / steering rack only has 2 outer holes for adjustment. The optional (is it optional?) aluminum steering rack has four outer holes for more adjustment.
Can you tell me the location of the 2 new holes? Are they closer to the front wheels or on the inside in comparison to the stock?
#9685
It's all about setup.
The twitchiness described by some are referred to as added steering by others
You can easily tune out steering and calm it down
Alu. ackermann bar is used to make the steering more precise and adds the option of also adjust the length of the steering rod (not just forward/back).
The extra holes are closer to the wheel making the steering link shorter.
Bent
#9686
Don't worry.
Bent
Bent
Do you feel this part is necessary for high grip tracks like mine?
The added holes are for less initial turn in?
#9687
#365354 -0.75mm (2pcs) = 3.8mm
#365353 0mm (2pcs) = 4.6mm (XB2 stock front)
#365355 +0.75mm (1 stripe)(2pcs) = 5.3mm (used on front of XB4 with #369912)
#365356 +1.5mm (2 stripe)(2pcs) = 6.1mm (used on rear of XB4 with #369913)
#365357 +2.25mm (3 stripe)(2pcs) = 6.8mm (XB2 stock rear)
#365358 +3.00mm (4 stripe)(2pcs) = 7.6mm
#365359 +3.75mm (5 stripe)(2pcs) = 8.4mm
The small inner flange that goes towards the bearing are not included in the measurements .
This flange adds 0.3mm on all the above numbers.
#9688
2016 slipper
I am building my 2016. Building the slipper I appear to be having a brain fart. Page 27 first 4 pieces make sense. The. It shows putting the second pin in against the spur. If I put the pin in after the spur I can not get the clutch plate over the pin. It all fits if I put spur, disk, plate, pin, disk, plate, nut. When don't this way the pin is on top of the plate listed as #3. Any help in getting me to understand? Video?
#9689
if both dots front and rear are inside, they narrow the track width.
If the front is inside and the rear is center, it adds toe
Now, if you have the width/toe set in mind.
the front rear hanger's are Up(higher than the rear), that will add Anti Squat.
Now, the overall pin height will change roll center.
there are many configurations, start with the book setup and change from there.
#9690
Bent
