Like Tree248Likes
Xray XB4 thread
Old 11-23-2015, 03:28 PM
  #9436
Trader Rating: 36 (100%+)
I have xb4 '15 can i use the slipper for xb4 '16?
raved007 is offline
Old 11-23-2015, 04:06 PM
  #9437
BentKa's Avatar
Yes
Bent
BentKa is offline
Old 11-23-2015, 04:10 PM
  #9438
BentKa's Avatar
Originally Posted by Chris Furman
Don't have the kit/manual yet. Do you have the part #s?
#362234 right
#362244 left
Bent
BentKa is offline
Old 11-23-2015, 04:24 PM
  #9439
Originally Posted by suby723
Congrats you will love the car it drives like a dream even compared to the 15. The only real part the car needs is the 12 degree caster blocks. Yeah it sucks having to drop that much $ on them but I took off almost half a second off my fastest lap by just adding the blocks with the same setup.
What affect does the 12 degree do that makes the car that much better
billsharp34 is offline
Old 11-23-2015, 04:49 PM
  #9440
symmetricon's Avatar
Trader Rating: 27 (100%+)
Less turn in less twitchy and more mid to exit steering.
symmetricon is offline
Old 11-23-2015, 05:31 PM
  #9441
Originally Posted by Ronisonce
Question regarding the ball diffs for the xb4, the option part. Are the balls and rings interchangeable (for servicing) with other manufacturers? The diff comes preassembled just wanted to check.
I don't think another manufacturers rings will fit but I believe you can use the 2.5mm schelle/avid diff balls. Also, not sure which one, but the xray diffs use an axial thrust similiar to what they sell as options as well.** I havent tried these parts, i just use the standard xray stuff so you'll have to check it out yourself as well.
punkracer24 is offline
Old 11-23-2015, 05:55 PM
  #9442
suby723's Avatar
Trader Rating: 21 (100%+)
Yep that sums it all up very nicely. It changed the entire characteristic of the car. I was able to drive the car a lot harder into the corners. I have never had such a great affect made by a simple bolt on. Just sucks it's $90 bucks but I would spend that any day to make a car that much better.
suby723 is offline
Old 11-24-2015, 02:17 AM
  #9443
You running those on clay or carpet
Old 11-24-2015, 04:08 AM
  #9444
suby723's Avatar
High bite carpet
suby723 is offline
Old 11-24-2015, 04:16 AM
  #9445
High bite carpet
How u think they would do on clay
Old 11-24-2015, 05:01 AM
  #9446
suby723's Avatar
I would think it would be great on med-high bite clay. I'll be running my car on a medium bite dirt track in the next few weeks.
suby723 is offline
Old 11-24-2015, 06:21 AM
  #9447
Default Body?
I've got a 15 and would like to get a body other than the stock X-ray body. Does anyone know where to get a aftermarket body for it?
justinchambers is offline
Old 11-24-2015, 11:22 AM
  #9448
Poppin Fresh's Avatar
The new 2016 body is a direct fit and looks really good. You should check it out.
Poppin Fresh is offline
Old 11-24-2015, 02:58 PM
  #9449
Cool thanks. I know the jcon body won't fit it's to short and I see a few different "wide" bodys but I'm not sure if that's what I need.
Old 11-24-2015, 03:19 PM
  #9450
HSV427's Avatar
Trader Rating: 30 (97%+)
Does anyone know what setup changes i would look at making to lose some initial steering, l am running the book setup on a low to medium grip track. Thanks
HSV427 is offline
