Xray XB4 thread
#4608
Just picked up one of these buggies, heard some people running 12mm hexes. Seen the traxxas ones and the exotec ones. I like the idea of the exotec ones because they are clamping. For those of you running the exotec ones... Which ones, which buggy are they for?
#4610
http://www.exotekracing.com/xray/
#4612
Im still having trouble with the rear end getting loose powering out of a corner. Its pretty violent to where there is no chance in saving it. Im running the standard clay set up with no limiters, 5/3 diffs,40/27.5 AE Blue fr AE Green rr. My tires are right because thats what everyone is running. Any suggestions?
#4613
Yes. If running the 2013 like I think ez is. Removing the spacer will help a lot. I may take it out of my 2014 and see. Still tends to not want to rotate as much as I would like. Will try a lighter sway bar as we'll, but don't want to completely remove it. I think more then anything I need to run my typos at least in the rear for better traction then the dirt webs until they come around a bit more.
#4616
#4617
-Try 6 deg caster blocks, to reduce on power steering coming out of turns
-Raise rear link to up position
-Add weight to rear, use heavy batteries
-use short wheel base (=rear hubs front position)
Those rear springs are too light for the car IMO. The suspension geometry and car width is way different to AE B44.2, so copying shock springs from it isn't the best way.
#4619
#4620
