The AE FActory Team B44.2 Thread >
Old 10-01-2015 | 05:17 AM
  #8266
Originally Posted by RobsRacin
Nope, not enough room from the center slipper back.
Thanks.
After a couple runs at the track yesterday, I noticed the motor starting to get hot (Reedy 8.5T). I'm going to go down a tooth or two on the pinion, but does anybody run a fan on theirs? Will it even fit under the body?
drewbagel423 is offline
Old 10-01-2015 | 11:58 AM
  #8267
Jerm13's Avatar
Originally Posted by drewbagel423
Thanks.
No fan, just a little slit on the body with it pulled up to pull the air over the motor. Comes off at 140-150 after an 8 minute run.
I really don't think there will be enough room for a fan on the motor with the top plate, drive shaft and body. Possibly...
Jerm13 is offline
Old 10-01-2015 | 12:06 PM
  #8268
Jerm13's Avatar
Hey guys just picked up a used B44.2 on here and am actually enjoying it more than my B5m in stock class. Was wondering if there was an easier (read: more affordable) way to be able to run shortys than with the Schelle conversion?
EDIT: Reading back a couple pages it doesn't appear to be possible, unless someone knows of something I missed?
I put the Schelle chassis on about a month ago.... Wow, what a difference. Its worth the investment! I guess you could find out what parts you need to convert to the 44.3 chassis if you want to go that route. I think you need chassis, motor mount, and top plates. Possibly drive shafts but not sure. You are going to have to bounce between the 2 manuals for part numbers.
But I highly recommend the Schelle kit. It is awesome and goes together about as perfect as perfect could be.
Jerm13 is offline
Old 10-01-2015 | 02:55 PM
  #8269
RobsRacin's Avatar
Regional Moderator
You need the top decks, shafts(front and rear single the center section is moved up), motor mount, chassis, and the corresponding battery hold down for the chassis
RobsRacin is offline
Old 10-01-2015 | 03:40 PM
  #8270
Jerm13's Avatar
That's the reason I got the Schelle kit. It comes with everything you need including battery hold down, motor mount, upper deck, chassis and protector. Everything else is used from the kit. The chassis layout lets you choose what ever layout you want. Motor front or back, servo on either side, and can be configured back to the normal saddle pack style if you choose.
Well worth the $110 for the amount of options you get. Plus the parts quality is top notch.
Jerm13 is offline
Old 10-01-2015 | 07:36 PM
  #8271
RobsRacin's Avatar
Regional Moderator
Yep, the parts to put it together are close to $175 I believe back when I priced it out. To convert the whole car was just shy of $300 with gear diffs... cheaper to just buy a 44.3
Old 10-01-2015 | 07:39 PM
  #8272
Yeah that's why I was looking for a cheaper option, because then I'd just sell the .2 and pick up a used .3
Old 10-02-2015 | 04:35 AM
  #8273
Jerm13's Avatar
The Schelle conversion kit is $115.... When did you price it out at $175?
If you want to get the gear diffs, that's another $90.
Jerm13 is offline
Old 10-02-2015 | 07:34 AM
  #8274
RobsRacin's Avatar
Regional Moderator
You will need 2 of the #9935 and so in total that is $442.77..... $175 was bare essentials to get a shorty in the car with associated parts. So really just top decks, battery cradle, and the motor mount and a few other odds and ends.
Attached Thumbnails The AE FActory Team B44.2 Thread-screen-shot-2015-10-02-10.28.27-am.jpg
Old 10-02-2015 | 10:04 AM
  #8275
Jerm13's Avatar
The diff cases from the 2 can be used on the 3. You just have to grind the nub off the inside if you plan on running the shorty layout.
Looking at your price list, you are looking at doing a full 44.2 to 44.3 conversion. That's is not cheap. Best to just buy a new 44.3 kit.
If you just want to go to a shorty layout while still using all the 44.2 parts, the Shelle, as I said before, is probably the best option.
Jerm13 is offline
Old 10-02-2015 | 10:13 AM
  #8276
Jerm13's Avatar
And your list id kind of redundant.
If you buy the front or rear diff, you don't have to buy the diff out drives. They come with the diff kit itself. Same with the center diff.
And the center CVDs are specific for the gear or ball diffs. You don't need both( you already have the ball diff ones on your 44.2). Also, you wont need the input shafts as they are part of the CVD kit, just the input gear and clip.
Jerm13 is offline
Old 10-02-2015 | 03:59 PM
  #8277
RobsRacin's Avatar
Regional Moderator
You are right. We are in the same frame of mind just showing what it would take if you wanted to purchase ALL the parts to convert to a 44.3. It still is going to be nearly the cost of the kit to upgrade
Old 01-08-2016 | 05:46 PM
  #8278
Scionara05's Avatar
Well while on the subject i was thinking of doing a .1 to a .2 schelle shorty setup for 115 what else is needed besides center bones and top cover plate
Scionara05 is offline
Old 01-08-2016 | 07:16 PM
  #8279
Jerm13's Avatar
We were on the topic 2 months ago...
You don't have to buy anything other than the full Schelle Kit. It comes with the main chassis, top decks ( both) battery hold down, chassis protector and hardware. Everything else you already own. Its a true conversion kit. Not one where you have to pick and choose and pull pieces from here or there. It also allows you to run what ever configuration you want. Motor in front dhort, motor in back shorty, saddles, and servo on either side.
I have since put the gear diffs in mine and it has really woken the car up. Went from mid pack/ back marker to top 4 almost every weekend. Myabe Im just getting used to the car and how to drive it
Jerm13 is offline
Old 01-09-2016 | 05:18 PM
  #8280
Can anyone tell me what rpm ball cup size I need for a stock setup. Just got the car and the sae size is confusing me lol.
bhilly82 is offline
