The AE FActory Team B44.2 Thread >
Old 04-20-2014, 04:21 AM
  #7516
Svendc's Avatar
ok, rerbuild my diffs and break them in like un4racing his video.
much smoother under high pressure!!!
make also a miscalculation, the forse of the slipper is stonger than 1 diff, but when i block front en rear wheels the forse of the both diffs together is much stronger than the slipper, so i can tighten the slipper further.
correct me if i'm wrong
Svendc is offline
Old 04-20-2014, 06:13 AM
  #7517
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Sounds like you have it. About 4-6 inches of slip is a good starting point.
UN4RACING is offline
Old 04-20-2014, 06:34 AM
  #7518
tony montana's Avatar
Trader Rating: 71 (100%+)
Hey guys still looking for a way to calm this car down. It's pretty bad when my mid motor car has more traction and I'm able to turn faster lap times with it. I did take the rear sway bar off and it did help a little. But it's like the car turns in so hard it breaks the rear loose. I also turned the travel down on the throttle to 85 percent as well. Also moved the Ackerman on the j concepts rack to the front hole. Car is all stock setup. Any help Is appreciated
tony montana is offline
Old 04-20-2014, 07:06 AM
  #7519
Svendc's Avatar
on the tracks i run, i had mostly the opposite.
try 30wt of 27.5wt and green or even black rear springs.
front diff little more tight
and loosen the rear diff 1/8 to 1/4 from tight, like un4racings video clip.
weight!!! try 40 to 87grams of balast between the saddles.
you van also experiment with the front camberlinks in 1e hole insteat of the 2e, it wil calm also the steering down.
check also ride height 1mm in front higher in your case.
and most of all the right fresh tires
good luck
Sven
Svendc is offline
Old 04-20-2014, 07:07 AM
  #7520
Tires were brand new and the correct tire for the track.
Old 04-20-2014, 07:11 AM
  #7521
gogi108's Avatar
Keep travel at full lock , I personally play with expo just to dumb down initial steering input , makes more forgiving . Perhaps diff settings are incorrect easy one to play with at the track
gogi108 is offline
  #7522
Svendc's Avatar
tkx for all your video posts, it makes the difference
Svendc is offline
Old 04-20-2014, 07:39 AM
  #7523
Would the avid chassis help or hurt my situation. I forgot but I'm also running the stock chassis but with the big weight between the saddles. Maybe the extra weight is causing the rear to swing it around?
Old 04-20-2014, 07:52 AM
  #7524
UN4RACING's Avatar
The Avid will plant the kit more on all four corners. Much better weight placement options. Try moving the front inner camber link to the inner hole on the top deck. If that isn't enough to calm it down add a shim in the front shock and move the front lower shock eyelets inward.
Work on the front. You can try a stiffer front spring first. Red is a good option.
Old 04-20-2014, 07:53 AM
  #7525
UN4RACING's Avatar
Thanks and your welcome.
Old 04-20-2014, 10:15 AM
  #7526
My bro just built a new 44.2 and we are having a steering binding issue I cannot figure out.
here is a quick video of the issue. any help is greatly appreciated! Hoping a missed something dumb/easy.
+ YouTube Video
iThinman is offline
Old 04-20-2014, 10:33 AM
  #7527
OK thanks will try the avid chassis
Old 04-20-2014, 10:45 AM
  #7528
Tech Legend
Wild Cherry's Avatar
When Hartson was here last week end had the chance to check out his ride very carefully.
It sported ball diff's & a proto type heavy duty CVA coupling for the rear drive shaft.
Wild Cherry is offline
Old 04-20-2014, 12:29 PM
  #7529
Svendc's Avatar
sounds... all new wheeler lol
Svendc is offline
Old 04-20-2014, 02:50 PM
  #7530
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Was it metal or the lighter beige plastic they use in the diff gear? They used a heavy duty couplings at the Worlds that resembled the beige plastic.
Jmuck69 is offline
