The AE FActory Team B44.2 Thread >
Old 11-12-2013 | 09:21 AM
  #6151
Waflet's Avatar
Originally Posted by fq06
It was posed a little while ago and I think the AE site has the list.
You can also pick up the Avid chassis and their .1 to .2 conversion kit... there is also a spacer for the slipper I think if you are going to keep the 2 pad slipper.
Of course the big bore shocks from AE as well.
Hideeho
If you want to keep the v2 2 pad slipper or the avid triad you do not need the spacer with the conversion kit. It comes with a longer rear center drive shaft & top plate along with an extra set of holes in the chassis to fit either fit either the conversion or the standard .2 parts. You only need the spacer in a full .2 with a triad or v2 slipper.
Waflet is offline
Old 11-12-2013 | 09:28 AM
  #6152
Wild Cherry's Avatar
Tech Legend
Originally Posted by xTotalghost
Can some help me find everything to covert my b44.1 to a b44.2?
Only difference between the 44.2 & .1 is it's 8mm longer & has 12 mm BB shocks .
If you race indoor the 44.1 is still a great ride....
Just install the 12mm shock and your all good ...
Wild Cherry is offline
Old 11-12-2013 | 10:03 AM
  #6153
vito's Avatar
what better the stock vts slipper or the avid one?
vito is offline
Old 11-12-2013 | 10:10 AM
  #6154
Thats exactly what I am running, I call it my B44.1-1/2 lol but I like the feel of the +8 chassis so I will eventually change over to the factory 44.2 setup, its only a few parts and can be found on ebay for much cheaper than the Avid chassis setup. (The BB's are the costliest part of the conversion, glad I already have those!!)
fivepointnine is offline
Old 11-12-2013 | 11:19 AM
  #6155
rdeppen's Avatar
I prefer the Avid. It's lighter weight and keeps it's set really nice. I could never find the perfect amount of slip with the VTS. Most pictures you see of all the top AE drivers most run the old vented slipper or an Avid
rdeppen is offline
Old 11-12-2013 | 11:38 AM
  #6156
Waflet's Avatar
Hideeho
I prefer the garodisk from rcshox.com. It took some breaking in (its not supposed to, but mine did), but after a few packs I got it dialed in & never have to touch it again. It never glazes, never needs maintenance & never wears out. I've been running one on my b4 for almost a year & have never done anything to it. Anything I ever drive with a slipper will always have one.
Waflet is offline
Old 11-12-2013 | 12:33 PM
  #6157
David Home's Avatar
Are AE planning on bringing out their own oil filled diffs for the 44.2?
David Home is offline
Old 11-12-2013 | 12:50 PM
  #6158
ryanpatrickgore's Avatar
i have the gariodisk too and it is a good product. i stopped running it because i could feel it had to warm up?. it was not consistent untill i had a few laps through it to get it warm im guessing. so on a 6 minute run... it didnt feel right untill about minute 2. overall a very awesome product, on a micro 6 minute level.. not consistent enough, especially when you only get 1 - 2 practice laps before the race.
ryanpatrickgore is offline
Old 11-12-2013 | 12:51 PM
  #6159
the incubus's Avatar
Being as their factory drivers are consistently running 410 Gear Diff's, I'm sure Associated is either looking to do just that or wait until a new 4WD is released and introduce Gear Diffs then. Those would then be an optional upgrade for the 44.2.
the incubus is offline
Old 11-12-2013 | 01:15 PM
  #6160
Tech Legend
Sticks & not very smooth compared to yellow pads JMO
Old 11-12-2013 | 02:53 PM
  #6161
Waflet's Avatar
Hideeho
Maybe thats what I was experiencing, rather needing to break in. I used to take 1-2 warm up laps. I have been taking more warm up laps as of late due to switching between different vehicles in one day. The last several races I have been waiting for the previous race to end & taking 5-6 warm up laps before the race starts & it has felt really good.
Waflet is offline
Old 11-12-2013 | 03:15 PM
  #6162
fq06's Avatar
I scuffed mine a little with some fine wet sand from day one and never noticed any warmup needed. Same from start to finish, haven't touched them since.
fq06 is offline
Old 11-12-2013 | 03:26 PM
  #6163
if i could get it consistent ALWAYS then i would cast my vote for product of the year.
Old 11-12-2013 | 03:31 PM
  #6164
fq06's Avatar
Give it a try next time you have the slipper out... you just built it so it may be a while before you want to dig into that though, but it won't do any wrong to try.
fq06 is offline
Old 11-12-2013 | 03:42 PM
  #6165
Tech Legend
Check these bad boys out ....
Vision Racing FCS pads ....
www.vision-racing.net
Attached Thumbnails The AE FActory Team B44.2 Thread-176876549fcs-slipper-pad.jpg
