The AE FActory Team B44.2 Thread >
Old 05-16-2014 | 12:27 PM
  #7651
Originally Posted by Wild Cherry
same size O ring , only the internals( spacers) are changed or different.
By O-ring bore I meant the opening on the shock body.
rc10gt82 is offline
Old 05-17-2014 | 09:25 AM
  #7652
Hi folks!
i'd like to ask do the big bore v2 shock bushing is the same size as the old bb v1 in b44? I'm asking because i ordered v2 big bore shock set for my b44.2 and i don't know if i need b5 shock bushing. Please let me know
K.Chmura is offline
Old 05-17-2014 | 09:31 AM
  #7653
Jdemonto's Avatar
Originally Posted by K.Chmura
Hi folks!
Nope
http://www.rctech.net/forum/13267294-post7650.html
Jdemonto is offline
Old 05-19-2014 | 05:06 AM
  #7654
greenruby79's Avatar
Hello, im leaning towards upgrading my cf chassis to alum ones. Which one is better, Avids or Schelle? Thanks in advance. Cheers...
greenruby79 is offline
Old 05-19-2014 | 05:21 AM
  #7655
TomErickson's Avatar
Is there a difference? They are designed by the same person. Avid is bronze colored and Schelle is black. They look very similar in both layout and details. I prefer the bronze/gold color myself.
TomErickson is offline
Old 05-19-2014 | 05:44 AM
  #7656
Jdemonto's Avatar
The Schelle has holes pre drilled for the upcoming shorty pack conversion. I have the Schelle
Jason
Jdemonto is offline
Old 05-19-2014 | 06:09 AM
  #7657
Jason
THAT is a difference worth noting!! I would get the Schelle now then.
Old 05-19-2014 | 06:23 AM
  #7658
Jdemonto's Avatar
For sure I'm getting used to using saddle packs but shorty packs are easier and I'm sure lighter.
Jason
Jdemonto is offline
Old 05-19-2014 | 09:01 PM
  #7659
Thanks for the input guys. Cheers.
Old 05-20-2014 | 03:50 AM
  #7660
Hi could someone tell me what degree the b44.2 castor is please.
AkCustomz is offline
Old 05-20-2014 | 06:23 AM
  #7661
Svendc's Avatar
Ok guys, i have Just bought the schelle alu. The shorty compatiblity makes it very intresting. Most of the time I run my b44.2 on Astro An carpettracks, so morge stiffer chassis is A good option I think.
Svendc is offline
Old 05-20-2014 | 08:12 AM
  #7662
So my b44 rear tires are really loose and I don't know why. I run on and indoor clay track running Stevens set up for the reedy. I am running gold barcodes
xTotalghost is offline
Old 05-20-2014 | 08:31 AM
  #7663
Wild Cherry's Avatar
Tech Legend
Just installed my old C4 12mm shocks .
Been trying pistons & oil combo's.
Tried to make 4 hole pistons work.
The 55 size was ok, but not enough pack.
So I tried 4 hole 56 , only to end up way to stiff.
Next combo I tried is 3 x 1.4 .
I used a flat piston in front with 37.5 w & tapered 3 x 1.4 32.5w in the rear.
This proved to be very good.
The tapered piston in the rear allows a heavier oil with out losing proper shock action. They bring improved landings and the thicker oil helps control roll.
Still working on , if I discover a even better shock package will post about.
front
Ae blue spring,flat 1.4 x 3, 37.5 w, 1 x .030 limiter.
rear
Ae green spring, tapered 1.4 x 3, 32.5w, 1 x .030 limiter.
Wild Cherry is offline
Old 05-20-2014 | 09:16 AM
  #7664
gticlay's Avatar
front
rear
Just how much difference do you notice with the tapered vs flat? I'm curious because I accidentally bought tapered.
gticlay is offline
Old 05-20-2014 | 09:43 AM
  #7665
Tech Legend
Gti
A little better handling and improved landings, give the combination a try .
Biggest difference is the improved stability & improved turn in entering the corner.
I'm running 21 mm & 20mm rear ride height .
