Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 10-11-2012, 07:15 PM
  #1411
Weazsel's Avatar
Trader Rating: 70 (100%+)
A short vid of my buddy running some practice laps. The car is just so so good.
+ YouTube Video
Weazsel is offline
Old 10-11-2012, 07:25 PM
  #1412
Trader Rating: 21 (100%+)
Thumbs up
+ YouTube Video
sweet jeasus!!that car is by far the best 2wd ive ever witnessed!! totally stuck to the track!!
what tires was your buddy running? and is that out of box setup?
toyota 2jz is offline
Old 10-11-2012, 07:28 PM
  #1413
Weazsel's Avatar
Yeah it looks pretty darn good huh? He's a real talented driver as well but a car this good doesn't hurt!
He's running Proline Suburbs M4 compound front and rear. Closed cell foams front and rear.
The set up is a little different from out of the box. I'm sure he could post it up for you guys once he's done testing... it's still in the developing stages.
Our track is low-medium bite topsoil/clay mix.
Weazsel is offline
Old 10-11-2012, 07:30 PM
  #1414
idrummerboy13's Avatar
Trader Rating: 15 (100%+)
He's running Proline Suburbs M4 compound all around.
Wow that thing steers.
Of course now I sorta want it but my rb5 is pulling low 17s and that's 3 days on it.
idrummerboy13 is offline
Old 10-11-2012, 07:38 PM
  #1415
Weazsel's Avatar
Ok great, here's where you discuss the RB5 if you weren't sure: http://www.rctech.net/forum/electric...hread-337.html
Weazsel is offline
Old 10-11-2012, 07:41 PM
  #1416
carcrusher46's Avatar
Trader Rating: 17 (100%+)
Just finished up the body on mine, didn't come out too bad! I like to keep things simple:
carcrusher46 is offline
  #1417
Ball buster. You racing tomorrow there tuff guy?
Haven't seen you in a while hopefully there is a good mod turn out. Anyways. About this car I'm driving licatas tmrw. It looks stupid fast
Old 10-11-2012, 07:44 PM
  #1418
Thumbs up
ok cool thanks for the info!!
Old 10-11-2012, 07:46 PM
  #1419
Weazsel's Avatar
No problem man. Let me know if you need any help!
Weazsel is offline
Old 10-11-2012, 07:55 PM
  #1420
Weazsel's Avatar
Hey Matt!! All stickered up and ready to go I see!
Weazsel is offline
Old 10-11-2012, 08:19 PM
  #1421
Originally Posted by TCR
Jason,
Your set-up states you are not running a slipper and 64 pitch gears. I was just wondering how is this achieved and who's gears are you running?
Also not sure how the calculation on 64 pitch gears is but isn't
88/33 * 2.6 = 6.9333 FDR?
Your set up looks fast, I'd like to try this when my RB6 comes
Cheers,
I am using Kimbrough gears and something similar to this http://www.speedtechrc.com/store/ebp...id=322&id=7716
Also oops that's a typo, it should be a 43 not 33
In 48p it's like running 66/32, or 72/35 which doesn't fit unless you grind the motor plate and shave the gear cover.
To calculate between 48p and 64p
88/2 x 1.5 = 66
43/2 x 1.5 = 33 (rounded up)
This gearing gives the car power much higher in the rpm range (not much torque), which means if you slow down to much in a corner or scrub speed it takes a little more to get going, or it might be harder to clear a jump if you don't keep the speed up. I recommend you start a little lower to be honest, 72/33 48pitch and go up or down from there.
Jason.Dias is offline
Old 10-11-2012, 08:38 PM
  #1422
Trader Rating: 18 (100%+)
+ YouTube Video
That car looks great there, nice vid.
spectre is offline
  #1423
racer x 1's Avatar
Trader Rating: 27 (100%+)
88/2 x 1.5 = 66
I know I havent seen your car in a while Jason but with my sp2 I was running 72/31... with a high torque rotor (thunder power motor) and the car was ballistic and clearing the triple for the whole pack as well. thats what im gonna start this beast at... any input?
racer x 1 is offline
Old 10-11-2012, 08:39 PM
  #1424
Energyzer's Avatar
Thanks for the help on the plugs guys!
I've built the front end, and the arms are quite stuck... Not moving freely! I don't know what i've done wrong, but i checked it and the shaft that goes inside the arm gets tightened when it reachs the arm... Don't know if i'm being clear enough!
Laters
Energyzer is offline
Old 10-11-2012, 08:42 PM
  #1425
yea that should be fine to start, you might want to go up a pinion though.
I just updated my setup from last night, this will probably be the last "club racing" setup I post for the current layout.
http://jasondias.com/2012/10/12/kyos...st-rc-raceway/
