Kyosho Ultima RB6 & RB6.6 Car Thread
#1441
Tried a set of golds on the car last night at practice, car was money, but now I need to address a slight push comming out of the corner, I tried lowering the front link my removing the outer shim on the hub but it got worse. Anyone have any suggestions? Only think I can think of is diff front tires or move the front camber link in a hole to make it longer
1. More static weight on the front of the car
2. Less front droop
3. More Anti-squat
4. Stiffer rear springs/oil
#1442
Alright guys im about to jump the gun and get one of these cars.
After reading most of the thread this morning, this is probably
a better choice to the Losi 22 which is in fact kinda similar.
I notice most of you are running 22-23 tooth pinions with an 8.5 motor.
Are you guys using the kit included shock oil? Or would it better to change it?
Thanks, because im probably gonna be running on a dusty outdoor track.
#1443
The kit shock oil is a tad light
#1444
hahaha the joke in that is that there isn't oils included in the kit.
#1445
use the Japan set up, its on here somewhere, that was at a track similar to your track as described.
#1446
Moderator
Trader Rating: 470 (100%+)
Amazing that a car with aluminum chassis and a narrow look must be exactly like a 22. Lol
I will never miss my 22. This wasn't directed at anyone in particular but it is just laughable that all over the Internet the car is being called a 22 copy. It will be great when the 22 cars at my track get lapped!!!
#1447
Thanks for the help on the plugs guys!
I've built the front end, and the arms are quite stuck... Not moving freely! I don't know what i've done wrong, but i checked it and the shaft that goes inside the arm gets tightened when it reachs the arm... Don't know if i'm being clear enough!
Laters
Laters
#1448
#1449
so they probably didnt include it because the car really needs to be adjusted
to your driving style. Most people dont use the kit oil anyhow
unless it's an AE kit. Yeah I wanna kick some 22 butt with the Kyosho as well. LOL
#1451
#1454
