Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 11-27-2012, 09:47 AM
  #2911
aloksatoor's Avatar
Trader Rating: 43 (100%+)
I have a different take. I do love the shorty but could never decide which position to put it. Rear = awesome fwd bite ok ok jumping, front ok fwd bite great jumper great in corners.
So I bought the ip 3800 stick full pack, it weighs less than my shorty and spreads weight accross the chassis .
aloksatoor is offline
Old 11-27-2012, 09:48 AM
  #2912
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Or you could run the shorty right smack in the middle of where a full sized pack normally sits to keep your F/R balance the same.
Cpt.America is offline
Old 11-27-2012, 09:56 AM
  #2913
fastestwon's Avatar
Trader Rating: 15 (94%+)
yes and you can also move it forward or back if you feel you need to .
fastestwon is offline
Old 11-27-2012, 11:33 AM
  #2914
aloksatoor's Avatar
Yep, I just love the ip battery for punch compared to the protek 70C shorty which tapered off in 6 months.
On another note, has anyone tried running saddle packs one all the way near servo and the other all the way to back? In theory more weight on/near axles should help weight transfer correct? Mostly for low mid grip tracks. I will have to rewire my esc for that but will do it sometime next week.
Old 11-27-2012, 12:22 PM
  #2915
Trader Rating: 101 (99%+)
I prefer running my shorty in the forward position and have flipped the rear battery holder around. No longer need to use foam spacers as it fits perfectly and is snug. If I ever needed to move it back, I just flip the brace around. If I want to run full size lipo, I remove the brace all together... R'Dub
Attached Thumbnails Kyosho Ultima RB6 & RB6.6 Car Thread-dscn9292.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-dscn9293.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-dscn9294.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-dscn9295.jpg
desertracerdad is offline
Old 11-27-2012, 12:37 PM
  #2916
CanyonCarverR1's Avatar
Have you considered moving your transponder to the opposite side of the car of the reciever? Then you could reduce that weight used for lateral balance.
Just a suggestion.
CanyonCarverR1 is offline
Old 11-27-2012, 12:57 PM
  #2917
fastestwon's Avatar
Just a suggestion.
from what i can see his transponder is right behind his servo in the middle
Old 11-27-2012, 12:58 PM
  #2918
I have my setup something like that, but the forward battery holder is all the way up against the servo and I have a piece of foam in front of the rear battery holder to take up the extra space.
Allen
abinder is offline
Old 11-27-2012, 01:17 PM
  #2919
Yes, it is. What I'm suggesting is that he move it to the left side of the chassis where he has some balast placed. I assume the balast is for lateral balance. If he moved the transponder there, he could reduce or remove the balast.
A minor detail for sure
Old 11-27-2012, 01:18 PM
  #2920
pekow91's Avatar
Trader Rating: 45 (100%+)
I have never heard of IP batteries. Can someone send me a link. I have larger stick packs (orion 90c 65000MAH) and I'm looking to get a shorty pack for my RB6 and wanted to see if anyone had any recommendations.
pekow91 is offline
Old 11-27-2012, 01:21 PM
  #2921
Trader Rating: 90 (100%+)
I just bought this: http://www.speedtechhobbies.com/inde...roduct_id=2638
b121774 is offline
Old 11-27-2012, 01:25 PM
  #2922
lbckevin's Avatar
Trader Rating: 107 (99%+)
Why would you mount a transponder back on the side...? It should always be in the front.
lbckevin is offline
Old 11-27-2012, 01:32 PM
  #2923
I appreciate the suggestion, thank you
I prefer the cleaner look and the car is balanced for my likinig. If I did run the PT on the other side, I would need either an extension (to run the wire around the cradle to the RX or to run the wires over or under the battery... Not fond of either route and I like having the PT closer to the front of my buggy.
Thanks again for the input!
Old 11-27-2012, 01:35 PM
  #2924
Trader Rating: 166 (100%+)
Originally Posted by b121774
I run that Lipo. Nice and punchy in my RB6, which I hope to race tomorrow....
God willing my lead singer actually goes back to Germany.
jpcopeland1 is offline
Old 11-27-2012, 01:37 PM
  #2925
rokitman's Avatar
Trader Rating: 128 (100%+)
+1 give ya 1/10th faster lap...
ok, maybe a 1/100th faster....lol
rokitman is offline
