Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 07-03-2013, 11:44 AM
  #7471
3srcracing's Avatar
Trader Rating: 29 (100%+)
Will the B4 wheels fit on this if they are pin/hex RB5 SP2? (I know this is the rb6 thread sorry)
So b4 wheels to RB5 SP2 worlds.
3srcracing is offline
Old 07-03-2013, 11:55 AM
  #7472
skengines's Avatar
Trader Rating: 226 (100%+)
Only hex will work.
I have JC b4.2 wheels that I'm using with no issues.
skengines is offline
Old 07-03-2013, 01:06 PM
  #7473
Originally Posted by Cspurlock
For those of you running MM, I tried the new Exotek narrow hangers last night. It made a difference in overall traction. Car felt much better with them. Didn't really notice any downside to them either.
Did you get them at OCRC or direct from Exotek?
Jam-Air is offline
Old 07-03-2013, 01:18 PM
  #7474
Sorry for my noob question, but I'm just getting started with the RB6. To go narrow MM, do I need the Exotek MMR hangere only, or the MMR2 as well?
Thanks.
mlinder
mlinder is offline
Old 07-03-2013, 01:34 PM
  #7475
Trader Rating: 31 (100%+)
direct
You need the narrow MM rear hanger and the std RF narrow hanger.
Cspurlock is offline
Old 07-03-2013, 03:16 PM
  #7476
direct
Thanks, Was able to get a set out, be here Friday.
Which rear arm? 521-1 or stock rb-6
Jam-Air is offline
Old 07-03-2013, 03:38 PM
  #7477
521-1 and .5 hubs 3 deg antisquat 30deg kickup
Old 07-03-2013, 06:57 PM
  #7478
gelshocker's Avatar
Hey guys what does narrowing the front do to the car? Thx
gelshocker is offline
Old 07-03-2013, 07:12 PM
  #7479
Makes the car turn in harder, little loss in stability
Wider makes it turn in softer
Jam-Air is offline
Old 07-03-2013, 11:11 PM
  #7480
gelshocker's Avatar
Thanks, so going wide seems like one method to curb any aggessive steering.
Old 07-04-2013, 05:58 PM
  #7481
Today i tried 1 deg hubs with 3 deg of anti squat and it felt really good. Lots of traction inthe rear but still rotated in good.
Old 07-05-2013, 09:55 AM
  #7482
EJF
EJF's Avatar
Trader Rating: 41 (98%+)
I have a RB 6 on the way and have some questions on set up
what are the inserts in the caster blocks for? do they adjust overall caster ?
how how is the front end width adjusted?
does the car come with wide or narrow rear hangers
EJF is offline
Old 07-05-2013, 10:46 AM
  #7483
lbckevin's Avatar
Trader Rating: 107 (99%+)
Read post #1
lbckevin is offline
Old 07-06-2013, 02:27 AM
  #7484
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
Got a chance to take the new girl out,
Ran it all stock. It's pretty good, but will need a little more time to dial it in. The only thing I wasn't too thrilled with were the 5 hole shock pistons, seemed to lack just enough pack to make the chassis bottom out a little bit too much. Outside of that, I'm pretty impressed so far. Now some serious practice days at the track are in order.
Teufel Racing is offline
Old 07-06-2013, 10:16 AM
  #7485
jackcarter3's Avatar
You should've asked one of us at the track. You never drove mine when I had it but it was dialed. 4x1.3 ghea pistons is what everyone is using.
jackcarter3 is offline
