Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 12-01-2012, 09:10 AM
  #3031
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by eper
okay guys sorry for the delay. the set up is on petit rc setup
http://www.petitrc.com/setup/kyosho/...ne20121127.pdf
thanks to Arn0 for stepping up and getting it posted. thank you
Thx man. Btw, what position did you use for the rear inner link position and any ball stud washers?
Yeti AS3 is offline
Old 12-01-2012, 01:07 PM
  #3032
eper's Avatar
Trader Rating: 14 (100%+)
Middle hole no shims. By the way the front shock droop measurement should be 20.5mm. Sorry about that. I was trying so many things to get it to fit that when i filled the whole thing out again i was really burned out. I been super sick and beleive it or not just looking at a computer screen has been making me sick to my stomach and tired. Hope it works well for who ever tries it
eper is offline
Old 12-01-2012, 05:41 PM
  #3033
B00t13g's Avatar
Three rb6s made the A at our local toys for tots race today. 1st 2nd and 5th(me) all three of us are running completely different setups and all three seem to fit each of us better than our previous cars. Rb5s and b4.1s. Very pleased with my car. Also I tried the avid pistons today after the races and they felt very plush on the track. I ran the 4x1.3s with 37.5 front 32.5 rear and was very pleased. I also ran red front springs and yellow rears which was definitely a better choice for our track than the white/ red or gold I was previously running.
B00t13g is offline
Old 12-01-2012, 09:29 PM
  #3034
Mxer59's Avatar
Trader Rating: 114 (100%+)
I just made the jump from b4.1 WC to rb6,I've been building it today and I've tore the tranny apart 3 times cause it feels like a tight spot that I can not figure out? Any suggestions?
Mxer59 is offline
Old 12-01-2012, 09:55 PM
  #3035
OnRDPassion's Avatar
Trader Rating: 59 (100%+)
I went through the exact same thing myself. To be honest I gave up trying to figure it out and went ahead and ran a pack through the car and checked it out afterwards and was smooth as butter.
OnRDPassion is offline
Old 12-01-2012, 10:07 PM
  #3036
Mxer59's Avatar
ill give it a shot cause I have tore everything apart reassembled it even took ball diff apart and then when i put back together same issue. its only tight in one little spot when it comes around
Mxer59 is offline
Old 12-01-2012, 10:15 PM
  #3037
Yeah exact same thing that happened to me to a T. You'll be golden
Old 12-01-2012, 10:18 PM
  #3038
cnelson3's Avatar
Trader Rating: 66 (100%+)
the tranny gear mesh is tight. check for dirt or gunk in the gears. i would literally run a pick or the back side of an exacto inbetween every gear to make sure nothing is making the "tight" spot.
this has happened to me before and 100% it was because i had something in the gears.
cnelson3 is offline
Old 12-02-2012, 12:55 AM
  #3039
Try loosening the screws that hold your transmission case together. Mine was alittle stiff in one spot and loosening the screws holding the transmission case together solved it.
Allen
abinder is offline
Old 12-02-2012, 08:45 AM
  #3040
Mxer59's Avatar
Allen
I did that also, Ill tear it apart one last time and see. I screwed them in to where there just flush with motor mount
Mxer59 is offline
Old 12-02-2012, 09:11 AM
  #3041
chrispattinson's Avatar
Here is my RB6 ready for racing at Seaham / Jarrow club in the UK tonight.
Stunning paint by Andy Pearson.
chrispattinson is offline
Old 12-02-2012, 09:56 AM
  #3042
Mxer59's Avatar
Sorry for all the questions new to Kyosho cars, does anybody make a 72t spur for it?
Mxer59 is offline
Old 12-02-2012, 10:06 AM
  #3043
BranVita's Avatar
Trader Rating: 39 (100%+)
AE,Avid, and JC, but you will need to buy slipper pads aswell.
http://www.amainhobbies.com/product_...-Spur-Gear-72T
BranVita is offline
Old 12-02-2012, 10:12 AM
  #3044
fastestwon's Avatar
Trader Rating: 15 (94%+)
AVID sells a complete slipper clutch for the car you will need both of the following .
AV1020STK
AV1020-TOP-KYO
fastestwon is offline
Old 12-02-2012, 12:32 PM
  #3045
Trader Rating: 62 (100%+)
Anyone got their Avid topshaft and slipper working. Those who ordered earlier this week should have them by now. Mine is still in the package and will be installed soon. Just wondering who got theirs done and got it running.
sipaboy is offline
