Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 01-21-2013, 05:10 PM
  #4531
gelshocker's Avatar
Glimpsing at these pics I'm seeing a stadium truck.
gelshocker is offline
Old 01-21-2013, 05:19 PM
  #4532
seth556's Avatar
Trader Rating: 43 (100%+)
Hey guys, I just got the RB6 and it drives well but it's like I have to drive it very carefully as it wants to drive all from the front. Going into the corners it feels good but then wants to pivot on the front way too much. It seems very characteristic of rb6's. Plenty of forward grip, just need it to be more lazy in the middle of the corner. It's fast, just feels like it always wants to kill me in the middle of the corner.
seth556 is offline
Old 01-21-2013, 05:27 PM
  #4533
teeforb's Avatar
Trader Rating: 94 (100%+)
Originally Posted by Trevor Williams
my kyosho gunmetal servo horn fit perfect with no issues.....
why TLR?
You have a link. Can't seem to find it under rb6 or rb5 parts on amain.
teeforb is offline
Old 01-21-2013, 05:29 PM
  #4534
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
I think it is for the lazer and is under the parts category for it.
Posvar is offline
Old 01-21-2013, 05:38 PM
  #4535
Trader Rating: 101 (99%+)
Default Kyosho Alum servo horn
Kyosho part# LAW42
desertracerdad is offline
Old 01-21-2013, 05:43 PM
  #4536
Moderator
Posvar's Avatar
Backordered at amain. I bought mine here...
http://item.mobileweb.ebay.com/viewi...or=true&mid=IP
24.40 shipped to me. Not too bad
Posvar is offline
Old 01-21-2013, 05:44 PM
  #4537
teeforb's Avatar
Originally Posted by desertracerdad
Kyosho part# LAW42
That seems the defeat the purpose. The plastic that fits on the servo is the 1st to give.
teeforb is offline
Old 01-21-2013, 05:46 PM
  #4538
Moderator
Posvar's Avatar
More for genuine kyosho gunmetal bling.
Posvar is offline
Old 01-21-2013, 05:51 PM
  #4539
offroad dude's Avatar
Trader Rating: 31 (100%+)
Originally Posted by TheChad003
What strap and battery braces you running?
Can someone give me the part numbers to make this holder? I looked on amain and I couldn't find anything but the battery post nuts.
offroad dude is offline
Old 01-21-2013, 06:00 PM
  #4540
B00t13g's Avatar
Finished up my wiring!
B00t13g is offline
Old 01-21-2013, 06:06 PM
  #4541
K_King's Avatar
Trader Rating: 47 (100%+)
Setup and track type?
K_King is offline
Old 01-21-2013, 06:35 PM
  #4542
joeymdz's Avatar
Here's mine. I placed the capacitor behind the r10 so it makest everything inline.. almost*. Once I get the mini servo I'll shorten the wires even more.
(Thank you Brandon for your help and ideas)
joeymdz is offline
Old 01-21-2013, 06:44 PM
  #4543
Moderator
Posvar's Avatar
I need to clean up my car after seeing all these wiring pics.
Posvar is offline
Old 01-21-2013, 07:29 PM
  #4544
Trader Rating: 18 (100%+)
Originally Posted by Cpt.America
Sure looks an awful lot like somebody elses layout I know
1 piece of advice, you get far better transponder performance when it's mounted horizontally instead of vertically. Might not be an issue for you, but if your RD ever says your signal strength is low, put that guy on top of the servo instead of behind it. I hear its also important to keep it off an alu chassis.
will move the transponder to where it should be, thanks!
Ctimrun is offline
Old 01-21-2013, 07:51 PM
  #4545
Is there a guide on how to read the setup sheets? I understand how to setup my car following the sheet but what effect will it do? Like what would 1mm shims on the ackerman do? Shims under ball studs etc.
HalfManHalfGod is offline
