Kyosho Ultima RB6 & RB6.6 Car Thread
#2551
The axle hole on the wheel seems smaller? If so, just open it up a little bit with a reamer or xacto if need be. No need to change axles. In fact, I ream all of my non-kyosho wheels to make the holes bigger.
If the hole in the wheel is to big I wouldn't worry about it because it will become centered on the hex instead.
#2552
I'm not sure if anyone has mentioned this yet, but when we were initially testing setups, Derek enlightened me that if you swap the front caster bushings from side to side (run the B side bushing on the front right, but hole on the inside) it will have the opposite effect, i.e. it will subtract that value of caster angle (2, 4 degress). So, with two different bulkhead/kickup settings, and 5 possible caster insert settings, you can end up with the following total caster angles:
Bulkhead @ 25deg: 21 (rf = B4 bushing), 23 (rf = B2 bushing), 25 (rf = A0 bushing), 27 (rf = A2 bushing), 29 (rf = A4 bushing).
Bulkhead @ 30deg: 26 (rf = B4 bushing), 28 (rf = B2 bushing), 30 (rf = A0 bushing), 32 (rf = A2 bushing), 34 (rf = A4 bushing).
If for some reason you wanted to run the holes on the outside, it would be the opposite of this, i.e. the B on the right side would add caster, A would subtract.
#2553
Anyone using the Jconcepts or AKA wheels on their RB6?
#2555
From what I saw there isn't enough thread on the rear axle, even with the standard non nylon m4 nuts.
I have some AKA wheels at present. Just mulling JC wheels as my normal retailer for Kyosho wheels is out of stock for fronts.
M
#2558
i'm really interested in hubs and rear hangers next.
#2559
i haven't ordered the cranks but i do have the rack. exotek has great quality, i don't thing you can go wrong with any hop-ups. i don't like to have all that alloy there and no servo saver so i'll keep mine plastic as they're holding up fine.
#2562
#2563
People, in a track like this:
http://www.youtube.com/watch?v=ADMB3Rpvuh0
do you think gold/gold springs + 450F/550R (ultimate) oils with the stock pistons could be a good setup? It's 100% astro.
Cheers
Cheers
